Starting engine for the first time in 3 years.
Old Apr 11, 2012 | 06:15 PM
grt05's Avatar
Everyone,
I plan on starting my '69 H/O for the first time in around 3 years and I'm looking for any tips you can give me.
I realize I should drain the tank of the old gas, I assume the easiest way to accomplish this is to drop the tank?
I'll also change the oil and check all the fluid levels.
Should I place a few drops of oil in each cylinder? Any other tips?
Thanks for the help.
Mike
Old Apr 11, 2012 | 06:19 PM
Jaybird's Avatar
Charge the battery and turn the key!!!
Old Apr 11, 2012 | 06:23 PM
Rickman48's Avatar
I'd put about 1/2 cup of Marvel Magic Mystery oil in each cylinder, and let it sit a day.
Next day, disconnect the coil, and turn the motor over to get the access out - use some rags to avoid a mess!
Put the plugs and wires back on, connect the coil, and start it! Vroom Vroom!!
Avoids broken rings from rusted cylinder walls!!
Old Apr 11, 2012 | 07:50 PM
I would agree that some sort of oil in the cylinders would be good, but I would not get too picky regarding which kind, other than to avoid the very thin, such as penetrating oil. I suppose an ideal would be a 50:50 mix of ATF and acetone, which would penetrate everywhere before the acetone evaporated off, leaving the thicker oil to lubricate.
I would respectfully elaborate on what I think Rickman meant:
If you put ½ cup of oil in each cylinder, if the plugs are installed, you must first turn the engine over by hand with a wrench four revolutions (2 and then another 2 for good measure) to be sure that the oil is out of the cylinders.
That much oil in a cylinder being turned by the starter motor will bend rods, unless you do it with the plugs removed, which will just make a mess.
Personally, I would put in a couple of squirts of oil, let it soak, screw the spark plugs back in, wing it over a few times (spark plugs will prevent oil from being sprayed out of engine), then remove the spark plugs, crank it until you see good oil pressure, then replace the spark plugs, pour a little gas down the carb (half a cup is good ), screw the air cleaner back on (to prevent catastrophic backfires) and VROOOM!!
Old Apr 11, 2012 | 08:14 PM
Rickman48's Avatar
I did exactly what I said on a '69 396 that sat outside for 6 years, without any problem.
Worked for me!!
Added 5 gals. of fresh gas, too! [leaded]
Old Apr 11, 2012 | 10:53 PM
oldsguybry's Avatar
NOVICE car nut
cool , this will come in handy when In try to get the 455 started
Old Apr 11, 2012 | 11:15 PM
oldsmobum's Avatar
You might consider pulling the distributor and priming the oil pump... I have heard a few horror stories about a spun bearing after a long sit on account of the dry start.
Old Apr 12, 2012 | 04:56 AM
m371961's Avatar
All the above sound good, including priming by the oil pump shaft. If you want to empty gas tank, get a electric fuel pump and hook it to inlet line at fuel pump and just pump out old fuel. If it looks rusty maybe install an in-line filter before carb on start up.
truerollers
Feb 28, 2017 01:00 PM
Nastardly
Mar 29, 2015 09:03 PM
kansjfr
Aug 13, 2013 06:02 AM
rgass
Feb 19, 2011 08:13 PM
44TEETWO
Feb 11, 2009 05:24 PM
