Starters and Alternators
Old Feb 17, 2016 | 02:02 PM
rktolds's Avatar
I'm going through my extra starters and alternators. Where can I cross reference the part numbers for the correct application? I have the Parts and Service manual but it is not as detailed as I wanted. Thanks.
Matt
Old Feb 17, 2016 | 05:10 PM
stellar's Avatar
stellar
Matt
If you list some numbers someone here may be able to help identify some.
Old Feb 17, 2016 | 06:34 PM
2blu442's Avatar
There was some discussion about accuracy. But I purchased one and have found some good info on keying out parts including alternators and starters.
John
https://classicoldsmobile.com/forums...olds-book.html
Old Feb 17, 2016 | 06:56 PM
rktolds's Avatar
John,
I have that book and I've used it to ID a few. I still have 10 that aren't ID'd. I can post some numbers tomorrow. But my question is where will you find the info? Thanks.
Matt
Old Feb 17, 2016 | 07:06 PM
junior supercar's Avatar
Mike Siedlik's book has numbers. Some have questioned it's accuracy though.
Google is your friend.
Old Feb 17, 2016 | 08:43 PM
2blu442's Avatar
Matt, I've got a GM reference book call Chassis and Body Parts Catalog, Oldsmobile models thru 1975, effective November 1979. I've checked a few items and sometimes its consistent with other references and sometimes its different. I'm not sure if I'm reading it wrong, or maybe this book has different part numbers from the references of the 1960's. So for what its worth, if you have a part number and it shows up in this book its probably right. But if it doesn't, then I'm guessing the number was superseded by the 1979 printing. If you want to post or email me some numbers I'll share what I can find.
John
Old Feb 18, 2016 | 03:13 AM
RocketDevo's Avatar
Hey Matt, if you list the numbers you have I can tell you what they belong to.
I have Delco-Remy starter and alternator numbers for pretty much every manufacturer and model ever made from the mid 40's to 1977.
Old Feb 18, 2016 | 03:57 AM
Octania's Avatar
I have a list of a few in my pn database
some came from an old MOTOR's manual, or Chiltons, and are questionable.
Others from factory PN listings
Sounds like R.Devo has all the good info there.
Old Feb 18, 2016 | 06:22 AM
mrolds69's Avatar
I probably have a few hundred AC, GM, DELCO, original parts manuals, + other resources...no kidding! You guys have seen me ID shocks, carbs, alts, dists, whatever. I can ID most any GM part, the superceded #'s, the modern #, etc. Prob is, it's extremely time consuming. I spent a LOT of time trying to help that bugdude ID that alt, when all he had to do was give the year or the number stamped on it. When you are trying to run these numbers down, the most helpful thing is the number + date code, even if you can't de-cipher the date.
Old Feb 18, 2016 | 11:57 AM
rktolds's Avatar
Here are the starter numbers:
1108387 1108768 1108386 1108427 1108352 1107320 1108386 1107809 1108794 1108759
Any help is appreciated. If you find them please let me know what resource you used. I've used GOOGLE and found 3 of these.
Matt
Old Feb 18, 2016 | 12:01 PM
mrolds69's Avatar
This is exactly what I'm talking about! If you found 3 already, why don't you say which 3 you found?
Old Feb 18, 2016 | 12:53 PM
rktolds's Avatar
found the 387's and 386 and 794
Old Feb 18, 2016 | 01:16 PM
mrolds69's Avatar
Ok...thanks Matt! Here's a couple more...1108352 Olds Toronado 69 70 ALL (maybe later, looking in a 70 book) 1107320 a good one Corvette 64-65 All 66-67 327 also some Camaro + others. Resource 1970 TBA
Old Feb 18, 2016 | 01:29 PM
mrolds69's Avatar
8352 also fits some Caddy aps. 1108427 1970 Chev Pass 350 w/ auto trans
Old Feb 18, 2016 | 02:07 PM
rktolds's Avatar
thanks for that.
Old Feb 18, 2016 | 05:25 PM
stellar's Avatar
stellar
8786 buick electra lesabre riviera 8427 chevy caprice impala chevelle malibu nova 7809 ? guessing industrial, but don't know. 8759 pontiac and firebird.
Old Feb 19, 2016 | 02:54 AM
RocketDevo's Avatar
I believe the only two numbers not already accounted for are:
1108768 correct for Buick 455CI, 1975 2nd production and 1976.
The 1107809 does not show anywhere? It is most likely a obsolete or superseded number. The 1107 prefix generally signifies an older starter, late 50's early 1960's.
In addition to what others have said, the 1108352 is correct for Toronado's 1968-1973. Interestingly it is also used in Chevrolet and GMC motorhomes in 1973.
Old Feb 19, 2016 | 06:55 AM
mrolds69's Avatar
I agree with rocketdevo, I had placed that 809 starter as 61 or back, but no exact ID. It's not really surprising those motorhomes used the Olds starter, many were 455 Olds powered. 1973...that was the year they looked like Scoobie's "mystery Van" kind of. I forget what they called them Voyager, maybe? There was a really nice one for sale on ebay, recently. There's also one inn the GM Heritage Museum. One final note for others...I already told Matt that for me.......it is way easier to find the aps if you give the date codes. That narrows it down for me a LOT. I use TBA's because they are right here at my fingertips. They don't list like 1108352 1108353..with the aps. I don't know of any source that does. Actually...I have a Hollander's in my basement that I haven't look at in 25 years! I'll have to check that.........
Old Feb 19, 2016 | 12:04 PM
rktolds's Avatar
Thanks guys. I'll be looking for TBA's to buy and add to the library.
rktolds
Feb 27, 2018 08:01 AM
lunaboy
Jan 24, 2016 07:57 PM
bobb
Apr 11, 2012 06:09 PM
77omega
May 18, 2008 08:11 AM
Jokers69
Feb 21, 2007 06:06 AM
