SSI Wheels for Fullsize cars
Yes, It is possible, as you can see by the photos below.
Stay tuned for a "how to".
Oops, forgot photo. See next post.
By the way, how did I know this thread was going to show Buick wheels?
And of course, that only works on J88s and 1977-1985 D88s that have the 5 x 4.75" bolt pattern. SSIs are simply Magnum 500 style wheels and those were only made with the 4.75" and 4.5" bolt circles, never the 5x5". There are aftermarket vendors selling billet versions of Magnum 500s (at great expense) so you might be able to get a custom set with 5x5, but no factory built Magnums ever came that way.
Each to his own, but to me, no matter what the center caps are, Buick wheels on an Olds still look like Buick wheels on an Olds.
I can vouch for that last statement.
A gent standing at the rear of my 1959 98 coupe said:
"An what sort of Chev is this"?
Yes, that 3 inch high O.L.D.S.M.O.B.I.L.E. lettering going right accross the whole rear end of the car is really hard to see!.
That was still a 5x4.75 AFAIK.
There was a chromed steel wheel however which I believe was only available in 5x5.
(D - bottom LH corner)
Of course, this is unrelated to this thread, which covers SSI wheels...
Yes.....if I only had a dollar for everytime I've been asked "what year is your Chevelle?"
You apparently missed this earlier post:
The 1977-85 D88s came with the smaller bolt pattern unless ordered with the HD suspension and brakes. The SSII/III wheels were ONLY made in the 5 x 4.75" bolt circle.
The big cars were part of the subject so I didn't consider it to be a threadjack...
It was apparently a "last minute" attempt as the brochures did not show it. It was option P05 (like the A-body ones) and was part no 400904. An August bulletin said there were delays bringing them into production (just like the A-body ones) and they expected to have them in November. A 12/19/67 bulletin postponed them indefinitely, and a 1/15/68 revision to the Assembly Manual officially removed them from availability.
5x5 SSI wheels How To
I finally got around to finishing my "how to" on SSI wheels.
The center caps are sport steering wheel horn buttons from a 70 to 75 Cutlass. Fusick sells them new for about $75 each
The center spring portion of the Buick cap must be removed to use with the Olds cap. The diecast studs that hold this part to the rest of the cap are simply flattened over on the end. If you center punch and drill these studs off then the spring center can be pried off.
The Oldsmobile center caps are actually center caps from a 70 to 75 Cutlass sport steering wheel. These are available from Fusick Automotive new for $75 or on E-bay or swap meets for less.
Once the back of the horn buttons are drilled and tapped for small screws. Then they can be attached to the Buick centers.
Nice wheels! What is your “I’m selling these today price?
They're hard to see, but this 1967 pre-production photo shows the Delta Custom Holiday Sedan wearing what I think are Kelsey-Hayes MagStar wheels. And they wake that big beast up right smartly, especially given the racy styling of the 67-68 GM B four-door hardtops.
MagStar:
Yup. The same MagStar Carroll Shelby selected for the Shelby Mustang, and Mercury used on Marauder X100s.
I once read that Oldsmobile purposely styled their cars to emphasize wheel styling. My own thoughts on that are that Oldsmobile wheel treatments are either flat-out gorgeous or so plain as to look cheap.
MagStar:
