speedometer not working
Old May 31, 2012 | 04:57 PM
jchavis44's Avatar
1965 delta 88 with 350 rocket engine....my speedometer is not working....... how can i remove it and check it..
Old May 31, 2012 | 05:29 PM
If neither the speedometer nor the odometer are working, the problem is very likely to be the drive cable.
I believe that the '65 B-bodies had the same speedo setup as the '68s - driven off of the Left front wheel hub. If so, if the cable is disengaged from the drive coupler, or if the coupler is damaged or missing, then it won't work.
Check inside your driver's side front wheel hub cap (NOT hubcap) and see if anything's amiss - no need to jack up the car or remove the wheel.
Old Jun 1, 2012 | 06:36 AM
jchavis44's Avatar
Originally Posted by MDchanic
If neither the spe yedometer nor the odometer are working, the problem is very likely to be the drive cable.
Thanks im hkin to look now and kust a heads up, im not a mechanic but i try to fix the simple tnigs, so please dont get aggitated if i ask wat seems to be a dumb question for some ..thanks
Old Jun 1, 2012 | 09:06 AM
You only have to worry if Eric can't read what you wrote. No such thing as a dumb question, but suggest you proof the post before you hit 'submit'. Good luck with your repair.
silverriff
Feb 13, 2008 03:59 PM
black betty
Dec 21, 2007 12:13 AM
70redvert
Dec 3, 2007 07:26 PM
Calvin.Norris
Nov 27, 2007 06:08 PM
<KEN>
Sep 22, 2004 08:39 PM
