Speedometer Cable Routing Blues
Old May 27, 2019 | 09:51 AM
Troys Toy 70's Avatar
Once Olds Always Olds
Since I just melted the casing on my brand new speedometer cable against the exhaust what is the proper routing for the speedometer cable under a 70 442.?
Also, once inside what’s is the path it takes inside up behind the dash? I had it coming up the left side of the steering column as you looking at the steering wheel but this seems to put is in a bind where it goes into the speedometer.
Any pics will help.
Old May 27, 2019 | 10:46 AM
66-3X2 442's Avatar
Any pics will help.
The cable routing should be in the PIM.
Old May 27, 2019 | 06:30 PM
BSiegPaint's Avatar
Do you have a 4-speed or automatic? 4-speed goes to the right of the column and up between the supports to the back of the speedo. When going through the firewall, it takes a turn towards the trans and is held against the firewall with a clip, then up over the trans and around to the passenger side to connect. The whole thing after the clip on the firewall should be encased in a thick rubber sleeve so it won't melt on anything.
Jacoz70442
Apr 18, 2019 08:13 AM
Bfg
Jan 16, 2017 04:38 AM
TheBigBlueBoat
Apr 19, 2016 06:55 AM
dster69442
Jun 2, 2012 05:07 AM
vagent
Sep 22, 2010 07:24 AM
