speedo cable install help
Am hoping to have time to change out my speedometer cable on my 69 442 this weekend. Can anyone tell me if it is possible to remove and re-install cable to the speedometer without removing from the dash? Looking for the easiest method. The other end goes to the passenger side of my muncie m-20. easy to get to.
On a '69, there is a spring clip that you have to press to release, then pull the cable at the same time, from the speedo head...on a '68 it has a threaded ring that screws onto the speedo...
You might be able to slide the new cable in completely from the transmission end, provided that the reason for the replacement is not a broken cable.
