Spark plugs for 72 CS
Tune up label on my car calls for a AC Delco R46S spark plug for my 72 CS 350 auto trans. However what are other options and why. What is a R45S compared to the R46S. What the heck are all those letters mean? Are Champion or NGK a good option? I just drive the car as a daily runner some small hiway trips of under 120 miles.
r45s is a one step colder plug, I have used both Champion and NGK plugs, both are good plus
the breakdown of the plug
R designates a resistor plug
'4 is the thread size 14mm
'5 is the heat range
'S means extended tip....
Attached is a good decoder I found on the internet
http://toms427impala.info/CT/ACPlugInfo.pdf
You asked a good question. The numbers have meaning. Review the following for a basic understanding of the meanings behind spark plug numbering from Champion.
https://www.championautoparts.com/Te...ark-plugs.html
If you're so inclined, you can perform a cross-reference on nearly any spark plug manufacturer.
http://www.angelfire.com/extreme4/sk..._REFERENCE.htm
