Spark Plug for Stock '65 330 4-Barrel?
Old May 20, 2018 | 08:41 AM
F-85 4-4-2's Avatar
AC Delco site says R43S for the 4BBL and R45S for the 2BBL. 43S is the "colder" plug. Thoughts? (2BBL & 4BBL HC originally took 44S and 2BBL LC 45S.
Old May 20, 2018 | 08:48 AM
Depends upon how you drive. With lots of WOT the colder plug; mostly easy cruising the hotter plug.
Old May 20, 2018 | 11:26 AM
F-85 4-4-2's Avatar
Easy Vista Cruiser-ing for sure. Anyone else?
Old May 20, 2018 | 07:27 PM
Sugar Bear's Avatar
The colder plugs were used on the higher performance/compression engines. Consider using the spec'd plug unless doing a lot of short trips then go up one heat range, I wouldn't go up two heat ranges. Pull a few plugs after a few trips after reaching full temp and read them.
The 330 4BBL should be the high compression engine...correct...anybody???
Good luck!!!
Old May 21, 2018 | 05:16 PM
F-85 4-4-2's Avatar
4BBL is HC. So says the label on the air cleaner housing, too.
Old May 21, 2018 | 05:27 PM
TripDeuces's Avatar
Didn't a red air cleaner housing signify an HC engine also?
Old May 21, 2018 | 06:14 PM
F-85 4-4-2's Avatar
Old May 21, 2018 | 06:28 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
I started using Autolites in all my Oldsmobiles since about 1985. Seem to last twice as long as any other plug. Its just a simple durable plug(was?). Though I haven't purchased a set since the MFs moved to china grrrrrr...so tired of china...
Cross ref is R43S = 87..........R42s = 73. I use the 87s
Old May 21, 2018 | 07:40 PM
Ozzie's Avatar
As mentioned, operational circumstances also mean something. I usually prefer the colder plug until too much deposit results; then move to warmer one.
Old May 22, 2018 | 04:50 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
The AC Delco and Autolite plugs aren't bad, supposedly made on the same line, just not as good as before.
Beau Dirt
Dec 27, 2021 03:02 PM
63 F85 Cutlass
Feb 8, 2015 03:20 PM
thapachuco
Jul 27, 2013 02:51 PM
66ninetyeightls
Mar 28, 2010 07:40 AM
kmccox11
Feb 27, 2009 06:51 PM
