Spark plug gap. 1972 Cutlass Supreme 350 4bbl. Stock
Old April 8th, 2020, 09:59 AM
Neuby7297's Avatar
What is supposed to be the correct spark plug gap for a 72 Olds Rocket 350 4 bbl. And what type of spark plugs you guys running. I hear two different stories on gap. .030 or .040? Please advise. Thanks
Also running a Pertronix ignition
Neuby7297 is offline
Old April 8th, 2020, 10:23 AM
Pat
patshotrods's Avatar
It shows 2 Different AC Delco Spark Plug #'s, the Small Plug is a R45TS and the Big Plug is a R45S. The correct Spark Plug Gap is .040. This is based on it still having its original Points Dist.
patshotrods is offline
Old April 8th, 2020, 10:53 AM
Agree w/ the above 0.040 - that should get the engine running fine until you perform the full tune-up at which time the gap may change as you set the dwell. Ensure you perform the tune-up in this exact order.
Assuming you have the stock OEM distributor & stock OEM contact points.
With the plugs gapped to 0.040:
(1) Set/Establish Dwell Angle to 30°;
(2) Set the timing to ~10° to 12° TDC (you must disconnect the vacuum hose at the distributor and plug the hose). If the air cleaner is removed, plug the vacuum hose fitting with some tape; and,
(3) Set the vacuum (via both carburetor A/F mixture screws) to the highest vacuum you can achieve (generally ~17" Hg).
Page 6C-11 of the 1970 1971 (edit) CSM. The tune-up parameters should be located on C.C.S. tag located on the fan shroud.
Vintage Chief is online now
Old April 8th, 2020, 11:16 AM
svnt442's Avatar
(2) Set the timing to ~10° to 12° TDC @1100RPM(you must disconnect the vacuum hose at the distributor and plug the hose). If the air cleaner is removed, plug the vacuum hose fitting with some tape; and,
Page 6C-11 of the 1970 CSM. The tune-up parameters should be located on C.C.S. tag located on the fan shroud.
The RPM is important here. Setting the initial timing at a lower RPM can result in too much initial advance, hard starting and pinging under hard acceleration and/or heavy load.
svnt442 is offline
Old April 8th, 2020, 12:24 PM
That's correct. And, that information can be obtained via the CSM or the fan shroud tag. Additionally, this can very w/ or w/o AC.
Old April 8th, 2020, 12:37 PM
Since the OP has a 1972 Cutlass, why don't we use the 1972 Chassis Service Manual? Big difference between a high compression 1970 motor and a low compression 1972 motor.
The first question is, WHICH 350 4bbl? The specs for an AT motor are different from those for an MT motor. I'll assume this is an AT car.
ALL 1972 spark plugs get an 0.040" gap. There is no fuzz on this. The Pertronix is irrelevant. Correct plug type is R46S (the MT cars used R45S).
Initial timing is 12 deg at 1100 RPM.
Slow idle speed is 600 RPM in DRIVE. Fast idle speed is 1100 RPM in PARK.
All of this info is on the tune up label on the radiator top panel.
joe_padavano is offline
Old April 8th, 2020, 01:06 PM
Oh yea, typo on my part. Should have been a 1971 CSM in my above post. Doh!
Noel Anderson
February 27th, 2021 03:54 PM
bonesbmx
June 2nd, 2020 02:10 PM
MaxDog
July 7th, 2012 09:13 AM
IZAOLDS
May 31st, 2011 12:52 PM
Quick Reply: Spark plug gap. 1972 Cutlass Supreme 350 4bbl. Stock
