Sorry going 350/350
Old Dec 4, 2013 | 10:13 AM
Lewbo's Avatar
Sorry going 350/350
Pulling my 215 and hydra out of my 1962 cutlass, just dont want to deal with it 215 runs great trans needs who knows, im in kansas 785 209 1341. 215 and trans for sale.
Old Dec 4, 2013 | 02:44 PM
Killian_Mörder's Avatar
Apologizing in advance?
Nobody ever apologized, before decking me one
Why not search nearby boneyards for a modern Land Rover 8, instead? It's an easier swap and you don't have to mess with altering the suspension to take a heavy cast iron unit. These engines are plenty powerfull for a light compact car
Old Dec 4, 2013 | 03:43 PM
billmerbach's Avatar
major noob
I think you'll find a great deal of power from this swap look for the 1968-1970 350 block with high comp pistons if you want the best stock engine
Old Dec 4, 2013 | 03:48 PM
gearheads78's Avatar
car guy
Thats much easier said than done. The Land Rover suggestion is a much better idea.
Old Dec 4, 2013 | 03:52 PM
major noob
I believe you guys I'm not saying its not by no means just giving him a suggestion if he goes 350
Old Dec 4, 2013 | 10:23 PM
64Rocket's Avatar
he is saying the engine is fine, just the trans is a P.O.S.
but the idea of the Rover engine and trans would be a good idea.
the only thing, I believe the Rover's are 4 wd, so the trans needs a extension housing set up for the slip yoke. At least I think that is what is needed.
If going with the iron blocks either chubby or Olds, suspension and brakes will need work. With the T-350, the trans tunnel may need some work to fit.
Plus some work to get a bigger radiator in. JMO
Old Dec 5, 2013 | 04:03 AM
No need to go Rover tranny. I assume he's got one of these dinosauers. They shifted smooth. But, were even less durable than the normal Hydramatic:
Adapting a THD onto the Rover block: http://www.hemmings.com/mus/stories/...feature13.html
...When considering using this transmission in older classic cars or non-GM cars, it would be easiest to find one with the Chevrolet bellhousing bolt pattern. This is because engine-to-transmission adapter kits to attach the Chevy bolt pattern are available for:
o Buick nailhead V-8
o Ford FE and small-block
o Ford 429, 460 and flathead
o Lincoln 337-cu.in. flathead
o Studebaker V-8
o Mopar big- and small-block V-8s
o 1954-1959 Mopar Hemi and Polysphere V-8
o Early Cadillac 346-cu.in. and 1955-1964 V-8
o Pontiac and Buick straight-eight
o Buick 215-cu.in. aluminum V-8
Old Dec 5, 2013 | 08:10 AM
Lewbo's Avatar
Old Dec 12, 2013 | 09:29 AM
Lewbo's Avatar
350/350
First of all thanks for all of the replies. I had problems with my new phone and wasn't able to respond. But the good news is I'm not going 350/350. After more research I have decided to get a bell housing converter from D and D Fabrications to make a TH200 Transmission bolt onto my 215. The reason I was sorry about the 350/350 thing is because I did not want to cut my car. Thanks Again 1962 Cutlass in Kansas.
84oldsDelta88
Dec 23, 2012 08:29 PM
Willidog
Oct 4, 2009 04:18 PM
The_Jeremiah
Aug 2, 2008 08:39 PM
72CUTTY
Oct 2, 2007 04:24 PM
ricebasher403
Sep 9, 2004 02:25 PM
