Slow convertible top
Old Jun 26, 2017 | 05:23 PM
Rocketbrian's Avatar
On a 71 Cutlass, I have to hold the switch for about 7-10 seconds with the motor whirring before anything happens. I'm thinking it is low on fluid. I have zero experience with convertibles. The manual calls for Type A, but I'm thinking it isn't made anymore as I haven't found any on store shelves. Can one use any Dexron fluid, or is something better?
Old Jun 26, 2017 | 06:06 PM
Gary M's Avatar
It's low on fluid. This is what I used
Old Jun 26, 2017 | 06:10 PM
Gary M's Avatar
Next question, where did it go? Lines may be loose or leaking or cylinders may be leaking. If you just keep adding it will continue to go wherever it's been going.i used a cheap clear catsup bottle to fill. 442.com has some convertible instructions on their website.
Old Jun 26, 2017 | 08:11 PM
Thanks for the info.
Old Jun 27, 2017 | 04:07 AM
Gary M's Avatar
Link to 442.com convertible info
http://442.com/tech/tech.html
click on the" mechanical box " ( of the four its the very left one)
Old Jun 27, 2017 | 05:33 AM
Mine also got worse and worse. When I replaced my interior I found a mess under the rear seat. The left cylinder was leaking. I replaced both cylinders. All ok now.
Old Jun 27, 2017 | 08:04 AM
Good to know, thanks. I'm working through a few electrical gremlins then I'll be attacking the roof system. It will involve cleaning and lubricating the mechanism and checking fluid level and I'll check those cylinders. I suppose you get a free undercoating under the rear seat if they are leaking.
Old Jun 27, 2017 | 03:11 PM
Tedd Thompson's Avatar
On my car it always runs down the rear foot well and is a b!tc% to get it out of the carpet. Happened twice luckily my carpet is ATF red to begin with. Come to think about it it's been replaced sense the spills..... Tedd
Old Jun 27, 2017 | 04:11 PM
When I got my car, the right side cylinder was leaking and the fluid just puddled up under the passengers side of the back seat. From what I remember, there's a depression or two in the floor pan where the fluid can collect.
btw
Brakes/Hydraulic Systems
Oct 6, 2016 10:21 AM
wolfman98
Site Help
Nov 19, 2009 05:06 PM
ztim
Jul 31, 2007 12:45 PM
bandit600
Nov 15, 2006 06:24 AM
69olds350
Nov 7, 2006 07:01 AM
