Single Post Car lift!!!
#41
I am a working man. Moving to south Texas after new year. cost are crazy!
Money is going into the engine and other car upgrades. I will be fine with the mobile single post. People have been using for years. I am always careful,
Miss my buddies pit in WV. , kinded like the ones at jiffy lube. But old school.
#42
There are still companies selling in-ground single post lifts if you are just looking for a way to have the lift take up only one bay.
This one was used when it went in 35 years ago and it is still going strong. In-ground lift prices are not bad if you can install it yourself.
#43
as i said earlier in this thread i grew up in my dads shop with 7 globe in floor single post hoists and transmissions were no problem,what was a little bit of a problem was the 4 wheel drive pickups,on those we usually pulled the transfer case and set it on the hoist above the post.those old np205 transfer cases were heavy and a pain to take off the trans jack
#44
Looks like those old, in ground lifts come with the chevymotor virus.
I'm not a fan of lifts in general; I'm too tall. 2 post can be a pain centering the car, and the correct spot front to back is right where you open the door the least.. 4 posts are a pain to do wheel work, but give you a nice tool shelf. I have noticed that getting up and down off the floor is getting harder. Once you're down, you can't fall, though.
#45
I have been working under lifts since I was 17 years old and that's been awhile. There are pros and cons and limitations with each style of course. It really depends on your requirements for the lift and what your space and financial constraints are as well. I chose a twin post for a number of reasons based on the work I do in my shop and what can be done easily on this type of lift. I would caution...even though you can do something on one type of lift or another doesn't mean that's the safest or best way to do it. I have seen far too many cars and trucks fall off lifts in my 35 years working on cars. It's not pretty and can be very dangerous.
Sure, there are times when the tall jack stands are necessary and helpful but they can also get in the way as well depending on the work being done. I just helped a friend swap out his trans and clutch on a 1-ton dually crew cab Dodge long bed truck. It was nice to have the extra tall-extra wide twin post lift where we could both easily stand under the truck when it was elevated. I'm nearly 6'5 so it's important to me to be comfortable under the vehicle. The lift I have does allow you to open the doors a good bit when it's positioned properly on the lift. I added a huge mirror in the front of my lift bay so that I can pull the vehicle in straight and get it centered on the first try. It was a trick we used at the dealership when pits were still the thing. Lol You can see it in the pics attached,
There are those that still desire to do work on the ground and to that I say----to each their own. If you don't have the ceiling height then I would look at all alternatives. If you do have space---the versatility of a twin post electric lift is pretty hard to beat for the cost IMHO.....
From what I see in the pics of that Cutlass on the single arm lift....I would definitely not be comfortable no matter how well it's designed even if I added jack stands. The margin for error is high and a simple slip or event when you are working on the car could be disastrous or deadly. Each person still has to be smart when all types of these lifts are used. Carelessness or complacency can and will get you killed!
#46
6' 4" here, and most lifts are too short. It puts me in an awkward crouch. Another disadvantage to lifts: when you drop a wrench, you have to bend over to pick it up off the floor.
#47
Well I hate giving up! But I will admit defeat. It will be chinese made. I would put 4 tall jack stands or more if needed under the car. There a lot of guys using them with no problems for many years now- NO tall jack stands. I would feel safe with the stands.
Looked online for single post car lift fails. Only found every other lift fails. I an OK being buried in my car, but not under it! I an careful anytime I am under a car, even foot and a half off the floor. Jack stands. floor jack, 6''x 6'', bottle jacks. Better safe than sorry..
#48
From everything I can find, it does appear it is made in China.
https://www.garageequipment.co.uk/bl...r-Lift-Factory
That said, it does carry a darn good warranty and appears to be well made. If I was going this route, I would want the permanently attached unit (SL-6), not the portable.
I would also note that Mohawk made a single-post lift, right chere in the good ol' USA. I do not know if they are still being made. I do know trying to find one used is all but impossible.more.
#49
The problem I see with the single post lifts is you'd better be perfectly level when you start lifting. If the unit itself is even slightly off level, things get top heavy very quickly.
I love my two post Rotary 9000 lb. You set the car on it, pick it up off the ground slightly, and rock it as violently as you can to see if you can shake it free. It goes up dead straight and is just as stable 6" in the air as it is 6' in the air.
You can't imagine all the things that can go wrong when you start removing or adding weight to a car that's on a lift. My 87 Mustang with no interior, motor. or tranny is only about 200 lbs nose heavy when you pick it at the intended pick points. I almost found out the hard way before strapping it to the front picking arms
#50
Pardon the rough autocad, but an 18' tall roof centerline with cathedral trusses (and parallel chord is also an option), on a 30' wide building would get me a 12' wide by 12' high space on the centerline, which can accommodate most car lifts. It would also help to put the uprights in between trusses front to back. Walls 10'. I forgot to add some dimensions to the sketch. Roof pitch 6/12. The house's chimney is 18.5' tall.
#51
Thanks Guys If I had the room for a two post I would. But cannot and get two cars in. I am a very careful guy. People have died with a car, foot and half up. Just me working on the car. 4 tall jacks, is a must in my eyes.
#52
Those are helpful pictures as I am picking a lift and trying to decide garage height. My house is short, and, although I could probably get a variance as I am one of the few single story ones in my subdivision, the code wants the garage to be shorter than the primary structure.
You need 11'-6" width for it
I don't have any pics of it all the way up but you get the idea:
#53
Excellent. I am 6'4". I bang my head on everything in the chassis department, but I have hardhats. I may get that model there. I need to pick up 3 @1970 A bodies, and an Econoline of the same vintage, as well as a 98 2 door Tahoe and a 2 door modern Tacoma. I think it could handle all.
Thank you.
Thank you.
#54
I have two styles currently a nice floor cable lift and a Scissor lift
I have a 10’ ceiling and it works perfect for my needs
picked it up used and had it inspected and Installed by the professionally for 1600 out the door
picked up the scissor hoist used for 300 best investment it moves around and works well for all 4 corners and general maintenance
#55
I've been looking at Wildfire XLT 4-post lifts, with bridge jack that allows one or both ends to be lifted from the ramps for tire/wheel work. When not in use for mechanical work, it would be used for vehicle storage so I could finally make use of all the bays in my garage, and my truck could come in out of the cold. The lifts can be moved around on casters, even after assembly.
#56
First and only American made single post car lift designed for storing two vehicles in the parking space of one. Not made to working on a car, But will be reaching out to them this week. See if they have something coming up. To fit my needs.
Not portable, but tight to the wall.
https://aclifts.com/lifts/m-1-single-post-car-lift/
#57
#58
I love my 2 post lift. I'm 6'2" and in my 70s. I wear a welder cap with a Wilson "Old School" catcher's cap over it. Plus I move slowly, headache's eliminated. I wear an LED headband light, love it. I have magnetic reach extenders plus I carry a small pocket magnet. I have a couple 1960's high barstool fiberglass chairs ( light plus easily moveable) usually I can sit while working on something. I have trans/rearend jack that I can use even if the vehicle is at full height. I have lifting devices in every bay/garage because I believe there's only so much tread on a tire so I'm saving my back/knees and hips. Start early and save your body. Jmo.
#59
Ceiling height is 10'-4, like I said before. I am 5'-6. So I am good to go. This is the first time i will be able to work standing up. Going to cut half the back of my old office chair..Have roll cart.
#60
The only issue is if you plan to do a lot of body/ paint work, 2 post lifts are a pain to work around. For those considering any bolt down lift, another really important point to consider is the thickness of your concrete. If it is too thin, you will need to cut out and re-pour patches under the mounting locations.
With thought given to the most important tool thread started last night, a good lift would rank right near the top for me. Add to that a good mig welder and air compressor as well.
#61
I know this is a old thread. Just seeing if anybody has gotten one since 2018??. Just can not crawl under a car anymore! Need a car lift, Garage is a two car. 10'-4'' tall. I am only 5'-6'' on a good day. If I bolt something down, only one car can fit. So I am looking at this one https://www.amgohyd.com/product/sml-...gle-post-lift/
Still need to find out where it made. I would put 4 tall jack stands under the car. Life is too short alreally. It would come in handy for my other classics to work on.. Thanks
I had a 10 foot ceiling, and ordered a bendpak 6lp. I could put our 55 truck, 70 442 and 64 cutlass all in the full up poisition without hitting a 10 foot ceiling. You can get a flush mount unit if you want to do the concrete work. I did not. It raises to 46" and is open in the middle. Sometimes the platforms are hard to reach around, usually not. I have a rolling seat and just work like that.
It also doesn't need super deep concrete like a two post. I drive right over it to park all the time. It is hard to push a non running car onto it, but i have a winch on the floor after tweaking my back trying it on my 70 442.
Maybe it doesnt meet your needs maybe it does. Also when we moved I unbolted it and moved it and reinstalled by myself
https://www.bendpak.com/car-lifts/mi...lifts/mds-6lp/
EDIT: no way to use my lift to remove a body from a frame...
#62
Not to change the direction of the thread but if parking under the lift is not needed, then you could look at something like what I have.
