Is this Show Winning 72 Incorrect?
I was reading the comments on Hemmings blog for this 442 that won the 2010 Summit Racing Equipment Show Car Series ISCA Finals.
The commenter took issue with the fenders the battery and the cable routing.
![](http://blog.hemmings.com/wp-content/uploads//2010/12/OldsEngine_800.jpg)
http://blog.hemmings.com/index.php/2...me-top-honors/
is this the car inline tube built ? looked at the link and yes it is the inline car I would bet it is right . You can run the wire both over the engine or over the fender well both are correct .
The red fender wells were not widely used in '72----supposedly only on the first 6 or 7 W30s. As for the battery and cable--side posts were used in '72 and I've seen un-restored cars with the cable routed different ways. I think trans. and other options determined the routing. I'd think Kryta would've done plenty of homework and not just slapped it together. As for being over-restored I say BS.---make it as nice as possible. That car is a kind of a rolling catalogue for his company's products so why not make it the best it can be.
Correct. 4-speed cars cable ran along the intake (so as to not interfere with the clutch Z-bar I assume) and Auto equipped cars ran along the fender well.
That's one of the little things bugging me on switching to a 4-spd or not... that cable (and not running along the inner well past the notch in the washer fluid bottle), the engine sticker up front saying 4-spd instead of auto, ppl asking why a 4-spd all the time (especially on a 350 Cutlass Supreme) at car shows, being hung up on originality (not all out concourse like Kryta's car though), etc. Can't make up my mind.
Looks good to me.![Cool](https://classicoldsmobile.com/forums/images/smilies/cool.gif)
In the '71 assembly manual it shows that the thermostat housing hose clamp screw should be 45 degrees from vertical to the driver's side of the car, not sure about '72.
I wouldn't think they would make such a totally unforgivable mistake like that but anything's possible.
![Roll Eyes (Sarcastic)](https://classicoldsmobile.com/forums/images/smilies/rolleyes.gif)
Other than engine/aircleaner being too glossy, it appears correct to me for a stick car. The (+) cable was run down the intake on those to avoid interference with clutch linkage.
I believe 72 batteries could be either top or side post depending on application or build date.
Beautiful yes, restored no. GM never a car with that level of detail. The body gaps, paint and fit/finish were never that nice. And every chassis left the plant with a coat of blackout that covered the suspension. Engines were never that nice, and they were test fired and tuned before they were shipped. That means paint got burned off and exhaust manifolds got rusty. That car is garage art, pretty but not technically a restoration.
Wrong upper radiator hose.
Really.
Those "GM" "white square" hoses were dealer parts dept. replacements, NOT used when the car was assembled at the factory.
I will have to look for the thread on this in another forum, but the owner of a repro parts house, who sells both types of hoses, and who owns a number of original GM cars of this period, was convincing on the subject.
edit: Here's that link to the other thread.
Really.
That's the way to do it.
Those private, "non-profit" auto museums are a really good tax shelter too.
In high school my buddy's father owned a plumbing company and he built the Ideal Plumbing and Heating '32 Ford five window coupe for nothing.![Cool](https://classicoldsmobile.com/forums/images/smilies/cool.gif)
![Big Grin](https://classicoldsmobile.com/forums/images/smilies/biggrin.gif)
NOS 65 booster with black master.
![](http://www.ultra-high-compression.com/nosbooster.jpg)
I made a comment on that blog about their other car, the 70 W-31, with the alum. sbo. I seem to recall that, that car also won best restored class in ISCA a couple of years ago If I'm right, that would make the 72, the 2nd Olds to win that class.
![Confused](https://classicoldsmobile.com/forums/images/smilies/confused.gif)
Maybe in '65 but I'm not sure that pertains to other years especially '70-'72 dual cylinder style where I've seen unrestored cars with rusty Master Cylinders from being unpainted bare iron from the factory.
I have to agree with you guys pertaining the the W31 with the aluminum engine. Look, I doubt if anyone here likes W31s more than I do, and I like that car an awful lot, but it belongs in a class with experimentals, or design study type cars. That engine, while exotic and rare was never mass produced and therefore shouldn't be classified with cars that were built on the normal assembly line. Kryta's cars are over-the-top and if I had his resources and parts availability mine probably would be too---I can't take anything away from him there. ISCA judges and OCA judges look at things in a different manner---what is correct for one is not for the other. The green car here is a wonderful car, extremely appealing, but technically a little too nice. Personally, I'm O.K. with that---Yes WAY cleaner and shinier than when it was originally built. Restored? No. Over-restored? Definitely. Would I own it? Absolutely!
Its an awesome example of what money can build, but its too perfect and maybe too fake to ever be a OCA class winner. It hasnt won yet so maybe the OCA knows that its not really restored with that engine in it.
#31
Hey TK65, I saw some pics DURING the resto. but none of the car prior to any work being performed. Now you got me thinkin'---I'll have to do some diggin' around and see what I can find on that car. Column shift, single exhaust, huh--never knew that----like I said, I only saw pics DURING the build. Until next time..... Dave.
#32
The pics I saw were, and still are, on wingsautoart.com The pics are really deceiving, since there are no shots of specific W31 parts. No interior pics showing the 4 speed, no motor shots of the intake or balancer, and the car did not have side stripes or W31 emblems. Remember this car was susposively low mileage and untouched. What pics they do show, show other things that contradict the cars "history".
Rear end is not aluminum
![](http://www.wingsautoart.com/projects/70olds/4.jpg)
Original floor with no hole for a shifter to poke thru.
![](http://www.wingsautoart.com/projects/70olds/10.jpg)
Under engine shot showing crossover pipe and no drivers side mid pipe, meaning single exhaust.
![](http://www.wingsautoart.com/projects/70olds/2.jpg)
#33
One thing on the painted master cylinders. I am no expert but I have heard many times on the difference between factory installed parts and dealer parts. To save a few pennies (important when building millions of cars, I guess), the assembly line master cylinder or tie rods or whatever might have a misted oil coating (or Cosmolene) to inihibit rust because it is manufactured and installed pretty quickly so only has to look good for a little while. Of course, it will later rust when the oil washes off. However, the same component made by the same manufacturer as a replacement part might be painted because it might sit on a warehouse or dealer shelf for a long time. So, just because you have an NOS part in a box that is painted, does not mean it was like that on the assembly line.
#34
Here is a super low mile, 1774, 73 SD 455 Trans Am. Nice but not like the "restored" to perfection W30.
http://www.yenko.net/ubbthreads/ubbt...39391&page=all
#35
i dont think the cars are for sale and or will be any time soon so we wonder why people get out of the hobby this guy builds or has built two very nice olds and many want to pick them apart if you strip cut and make a car like the w-31 with the rare motor (yes i said motor just to bug some) I say Thanks i will never have the means to have one like it but i like to see some one who can, can. in line tube has some pontiac that are just as nice .
#37
this is the 16,000 mile W-30 to compare it to. there are a couple things on this not right (like the hose clamp at the radiator) but interesting for a comparison. this was an automatic W-30 so the positive cable in on the finder. both have the same hole where the washer jar would be if it was on the driver side. mine had a B-4 stamp and was up side down and his is right side up. my X on the valve cover is not as bold. little things like that are neat to me to compare. just wish i still had it.
#39
Some people have to scrutinize and criticize too much or they just don't feel good about themselves.
That's a pretty damn nice engine bay.
I wish mine was that nice.
#40
Of course, a 1968 "W-30" with the emblems in the wrong place and thus the stripes in the wrong place won best of class at Seven Springs...
