Should my 67 Vista Cruiser have a fan shroud??
Old February 22nd, 2018 | 06:30 AM
Toocool's Avatar
My Vista cruiser doesn't have a fan shroud, should it have one? Where can I get one? It has that hand guard that hangs over the fan and rubber seals on the sides.
330 4 barrel, non a/c
Old February 22nd, 2018 | 07:00 AM
lemoldsnut's Avatar
It does make a big improvement. They did not come with them standard, Heavy duty cooling was optional with or without AC. There are reproduction fan shrouds made but, the general opinion is they do not fit well and are not well made. Originals are getting hard to come by and are spendy.
I have one available, the top plate is the same without without a shroud. There is a set of lower brackets that screw in to he lower radiator support that is mounts to and the two holes in the top plate you have that are not used are for a shroud.
Hope this helps
Larry
lemoldsnut@aol.com
541-815-4363
Old February 22nd, 2018 | 07:33 AM
Toocool's Avatar
Thanks Larry, I am going to drive the car more when it gets warmer outside and see if I really need one. If I think I need it I will contact you about yours.
Old February 23rd, 2018 | 12:46 AM
Gerald Nickels's Avatar
When you get ready look on Craigslist in the SF Bay Area. This guy sells 67 like new shrouds has 6 or 7 but pricy. Over $300
Old February 23rd, 2018 | 06:18 AM
Sheeeeyit. I paid 100 for each of mine years ago.
Bee Saint Louis
July 5th, 2019 09:58 PM
shamusj
January 13th, 2015 06:44 AM
1970 Post
August 6th, 2012 06:28 PM
KZ442
November 9th, 2010 06:01 AM
