Shock oil weight?
I think there has been a thread on this before. You might try the search function.
Try this link:
Shock Absorber Oil - ClassicOldsmobile.com
Try this link:
I've read discussions over at the https://forums.aaca.org/ about shock oils. I have no personal experience with them. They often mention hydraulic jack oil and motorcycle fork oil as modern replacements. Might search over there and get options, opinions.
I'd venture a quick call to Apple Hydraulics since they rebuild vintage shocks & most likely have excellent familiarity with your style of shocks. Shock oil must have the correct anti-foaming agent(s) to operate efficiently. As I stated in the referenced link (above):
I don't want to imply that is the correct oil for your shock(s), but a quick call would help to confirm (they rebuild Oldsmobile shocks, as well): 631-369-9616
They sell a quart of shock hydraulic oil for $19.95
Motorcycle fork oil (cruisers/baggers/bobbers) standard weight is generally 5. Happy medium is a 7. Most often no one goes above a 10. AMSOIL sells both #5 & #10 motorcycle fork oils. H-D refers to their fork oil as “E” (just as a general statement) which I think is ~7. Can’t recall exactly. I ride an Indian and use AMSOIL #5.
Tedd Thompson
June 14th, 2012 07:28 PM
