Seafom spray
Old Sep 21, 2023 | 05:51 PM
cublex's Avatar
Seafom spray
Has anyone use Seafom Spray on their vehicle...what kind of results
Old Sep 21, 2023 | 06:11 PM
Oldsguy's Avatar
Past Administrator
I used it on a 2012 Dodge Journey 2.4 L inline four. The engine had ove 100k on it. I sensed some improvement in driveability, less surging and smoother idle. Don't remember if mileage improved or not. I put some in the tank and also sprayed it into the air inlet before the throttle plate.
Old Sep 21, 2023 | 06:23 PM
cublex's Avatar
Seafom Spray
I just sprayed the carb on my 74 Cutlass Supreme and it appears to run pretty smooth..place some in tank as well...Thanks
Old Sep 21, 2023 | 06:29 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
The best stuff to bring back compression and remove carbon is Kleenflo Combustion Chamber. The Seafoam stuff is overated.
Old Sep 21, 2023 | 06:34 PM
cublex's Avatar
Where can you find it
Old Sep 21, 2023 | 08:26 PM
cfair's Avatar
I toss it in here & there on baseball-like superstition. Can’t say I can tell that it really helps.
Here in CA I toss Chevron Techron in my fuel injected cars too. More or less on superstition. I’ve nothing empirical to go on.
But then we all have the sauces we believe in.
I’ve recently begun adding Lucas Oil additive to my oil changes in place of 1 of 5 quarts of oil. It didn’t make anything worse, but I can’t feel the difference.
I wish I could see or feel that these things make a difference, but so far I’m at “Well, it didn’t hurt”.
Chris
Old Sep 22, 2023 | 03:04 AM
I used the SeaFoam spray by Oldsguy's suggestion in my 96 98. It stabilized the idle and improved driveability. Of course, the right thing to do would be to remove the throttle body and injectors to desludge them. For $20 though...
Old Sep 22, 2023 | 04:43 AM
BlueCalais79's Avatar
I've used SeaFoam and StarTron. The StarTron is my go to these days.
Old Sep 22, 2023 | 08:56 PM
Canada apparently, get it at Napa up here.
Old Sep 29, 2023 | 08:16 PM
harwooddan's Avatar
I put the liquid Seafoam in my 55' gas tank usually twice a year. Also use it several times a year in our regular daily driver 2000 era cars. Keeps crap out of everything and will not hurt anything. been using it for many years.
Cutlass Fan
Paint
Nov 16, 2020 07:54 PM
Rustbucket2
Paint
Oct 15, 2017 08:09 PM
foo
Paint
Jul 2, 2012 05:03 AM
Del70
May 8, 2011 09:27 AM
Want-A-Vert
Feb 14, 2007 11:51 AM
