Screw in or snap on
Old January 29th, 2019, 07:49 AM
delete
droptopron's Avatar
Screw in or snap on
Think these are snap on. Am I correct?
droptopron is offline
Old January 29th, 2019, 08:20 AM
'87 Delta 88 Royale
rustyroger's Avatar
Nope.
Roger.
rustyroger is offline
Old January 29th, 2019, 08:22 AM
Where's the picture??
Allan R is offline
Old January 29th, 2019, 08:28 AM
Easy enough to tell by looking at the wheel design. The screw in have a recessed base in the center of the wheel hub. The snap on has an elevated nub in the center the cap clips to. The snap on cap uses spring tension to hold the cap on, and is a smaller in size.
Bolt on. You can also see the hole the bolt thread through to attach the center cap.
This is snap on
Allan R is offline
Old January 29th, 2019, 12:01 PM
delete
droptopron's Avatar
Sorry about that. I did it from my phone & it said the attachment went
by https://www.flickr.com/photos/158535685@N07/, on Flickr
Old January 29th, 2019, 01:43 PM
Snap on caps and wheels. Later model production; likely from the 80's. Also note the 5 trim bezels on each wheel are more squared off and don't have the same profile of the earlier bezels.
Allan R is offline
Old January 29th, 2019, 04:26 PM
If I'm seeing correctly, those are 14" tires, so the wheels may be 14x6. Not very desirable.
Fun71 is offline
Old January 29th, 2019, 04:46 PM
Kenneth, I believe the later model 14" snap on center cap wheels were 14x7.
Allan R is offline
Old January 29th, 2019, 07:23 PM
delete
droptopron's Avatar
Thanks for confirming guys
first442
May 28th, 2019 08:40 PM
WTHIRTY1
March 22nd, 2019 01:32 PM
garyr6169
Wheels and Tires
September 17th, 2018 05:41 PM
dream66
Wheels and Tires
17
August 1st, 2018 04:03 PM
CyberCholo
Wheels and Tires
April 6th, 2014 05:37 PM
Quick Reply: Screw in or snap on
