scan and 3-D print
Old Oct 22, 2025 | 09:47 AM
Hairy Olds's Avatar
Shoveling Snow
scan and 3-D print
Is there anyone that could scan and 3-D print this plastic part?
I would need 10 of them.
Old Oct 22, 2025 | 10:02 AM
Loaded68W34's Avatar
Even with a very expensive printer it will be difficult to get high enough resolution to produce the correct grain. I think you will have better luck making a silicone mold using the original part as a pattern. Once you make the mold, you can use a 2-part resin to make as many as you want.
Old Oct 22, 2025 | 10:08 AM
acavagnaro's Avatar
x2. Printing won't capture that texture well.
Old Oct 22, 2025 | 10:20 AM
Hairy Olds's Avatar
Shoveling Snow
Well poop that's not good.
The grain is kinda the important part.
I would like to make a good supply of these and one at a time is not good.
Old Oct 22, 2025 | 05:32 PM
jensenracing77's Avatar
Talk to Eliot Erlandson on the 61-63 group. He printed a part that come out simply incredible! The typical lines you see on a 3D print was not there on what he sent me. He may not have time to do it for you but he can tell you what can and can't be done and likely hook you up with someone that can if he can't.
Old Oct 23, 2025 | 07:37 AM
You need to make a mold and cast.
Old Oct 23, 2025 | 11:18 AM
acavagnaro's Avatar
You can make a printed part look extremely good but it's time consuming and entails a fair amount of hand finishing (sanding!). You'd never be able to 'clean up' the textured surface he's looking for. That part needs a mold. Plus, the mechanical properties of the plastic will be much better with a molded part than they would with a printed part (although the printed part would probably be 'strong enough').
Old Oct 23, 2025 | 05:43 PM
The 3D printer that the guy has I mentioned prints it out in the finished product. This is not a standard 3D printer like most of us would have access to. There is no sanding involved with when he made me.
Old Oct 23, 2025 | 08:00 PM
Hairy Olds's Avatar
Shoveling Snow
I'm going to have to contact him. Do you think he is coming to MCACN?
Old Oct 23, 2025 | 09:40 PM
70W-32's Avatar
Peyton Hunt has a scanner and printer, you could ask him
Old Oct 24, 2025 | 03:08 AM
Not sure if he is going or not. He is typically more into custom cars than perfect restorations.
Old Oct 24, 2025 | 04:34 AM
JohnnyBs68S's Avatar
I could be wrong, but from the pad that item is photographed on appears to be 1" squares, so the object is just a few inches in length and ~1" diam?? If so, I suspect that the resolution problem reproducing the textured grain will be more with the 3D scanner than with the printer. True, a resin type printer will have smoother finish than a FDM type printer that uses filament. But there are chemicals (ethyl acetate) that when the printed part is exposed to it for a sufficient amount of time will result in a smoother exterior finish (this could avoid sanding and get in between the textured grain surface).
Old Oct 24, 2025 | 06:58 AM
Hairy Olds's Avatar
Shoveling Snow
Thank you gents lots of info to digest and people to contact.
The project has begun.
Old Oct 24, 2025 | 01:07 PM
illumined's Avatar
1978 Ninety Eight
Check out Additive Restoration. This is exactly what they do.
Old Nov 5, 2025 | 06:09 AM
F-85 4-4-2's Avatar
Would the mold/cast strategy also be better for these hard-plastic 2-seat Vista Cruiser pieces? Anyone have more detail on the silicone and process? Process can't risk being destructive.
Old Nov 5, 2025 | 08:00 AM
Hairy Olds's Avatar
Shoveling Snow
Molding process is not destructive to the original part.
The part coming out of the mold will look just like the part used to make the mold warts and all.
This isn't a cheap process and the silicone mold only lasts for a limited # of parts cast.
On another note I'm getting closer to having a sample to use in the mold.
The sample piece is oversized but I'm getting closer.
Old Nov 5, 2025 | 09:36 AM
F-85 4-4-2's Avatar
Those look good!
My main concern was removing the inside mold, didn't want to dig at it. If release is easy, I'm going to give it a try on a piece I can afford to sacrifice. What silicone?
5998DownUnder
Ninety-Eight
18
Sep 18, 2024 05:13 PM
tkcutlass
Sep 20, 2023 08:09 PM
75 W-30 H/O
Nov 23, 2022 02:58 PM
tkcutlass
Sep 26, 2022 08:08 PM
