Salvage Rusty Bolts & Parts...yes or no?
I would try to save them with some cleaners first, original always fit better and you may save some money. I use Easy Off for rusty parts that I need to get back to bare metal, works great.
If i had not kept any parts on my car that were rusted. There wouldn't be much car left. ![Big Grin](https://classicoldsmobile.com/forums/images/smilies/biggrin.gif)
Keep everything, Clean everything, Paint everything.
I shall stand by that until there is no rusted pieces left on my car.
-Tony
-Tony
Soak them in degreaser and remove grease and dirt first.
Next soak 'em overnight in evaporust or a similar product.
This will work for most fasteners.
If rust was so deep that metal is missing, replace them if they carry extreme loads, such as on suspension, driveshaft, motor mounts, etc.
The only bolts I know I would replace regardless of looks (if originals) would be the upper control arm shaft to frame bolts. They are abused by alignment techs and when they break, bad things happen. Since they are spaced out with shims at angles, they get unusual stress put on them.
There are many New Oldsmobile exclusive Nuts and bolt kits that work perfectly. I spent I think $50.00 and got a complete kit that included everything for the complete fenders forward of the car (included Headlight stuff/Radiator etc). Even included clips and shims. All were the correct size and shape and duplicated the original designs. They look great and worked perfect. My old ones were tired and looked bad. Good Luck.
Which bolts did you order and from where again? I think you said tractor supply a while ago? I'm replacing mine soon too. So if i could order an exact fit that would be perfect.
I'm worried about going to the hardware store and ordering bad bolts.
I save serviceable old bolts and hardware! Also if I need a fastener I go to a Bolt Store, as I prefer domestic! They are in the phone book and you will be surprised on what alot of them actually carry at reasonable prices!
There are many New Oldsmobile exclusive Nuts and bolt kits that work perfectly. I spent I think $50.00 and got a complete kit that included everything for the complete fenders forward of the car (included Headlight stuff/Radiator etc). Even included clips and shims. All were the correct size and shape and duplicated the original designs. They look great and worked perfect. My old ones were tired and looked bad. Good Luck. ![Smile](https://classicoldsmobile.com/forums/images/smilies/smile.gif)
Roger.
Now the upper control arm shaft to frame bolts are special - you need to get these from an Olds or Camaro parts house. They have splines to hold them in the frame to make alignments easier. Easy to find thankfully...
When i was at Partsource, they have a whole wall display of various nuts/bolts and clips that would probably be the same in Quebec. Check that out too - they even have the fasteners and bolts that go on the 442 grill tabs.
Only problem I've had using vinegar is the strong desire for fish/chips during and after working with it.
Im a big fan of the tumbler.I bought a Tumbler at Harbor Freight for @ 40 .00.Truly amazing.Brings everything back to original.Works like a charm.
X2 Works great! might need to wire wheel them after depending on how bad they were. Suppose to neutralize with water/baking soda mix to stop the acid from continuing to work.
Only problem I've had using vinegar is the strong desire for fish/chips during and after working with it.![Big Grin](https://classicoldsmobile.com/forums/images/smilies/biggrin.gif)
http://www.evapo-rust.com/
Leave it in there about a day. Solution goes from green color to dirty rusty color. Spray the screws clean with brake clean and they are like new. Of course anything heavily pitted wont look so good but if you just have surface rust it will remove the rust without touching the black (or plated finish).
Buy it at Harbour Freight.
I used to blast and tumble until i found this stuff.
No joke this stuff works.
https://classicoldsmobile.com/forums...l-results.html
I work in a steel mill where we have a "pickling" line, so i clean the bolts in a sandblast cabinet, then i take them to work and dip them in a sulfuric acid tank for 5-10 mins, then a phos tank for 1.5 mins, and finish them off with a dip in a phos neutralizer tank.
Hey, vinegar does work. I restore toy trains in my spare time and tried the vinegar to remove rust. It's a little slow, but if your not in a hurry, give it a try.
stetzie
stetzie
![Thumbs up](https://classicoldsmobile.com/forums/images/icons/icon14.gif)
Bolts have a life! When you torque them they strech(you can't tell with the eye). Old bolts have probably lost their tensile strength. Replace them (now or later?!)
Oldssupreme
February 6th, 2013 12:39 AM
