The Rustiest of Vehicles Thread
Those of us on the West Coast really don't see these issues. I am originally from New York and remember it well. Out here in Oregon unless the car is from a coast town or from the Seattle area we really don't see rust issues. We don't use salt on out roads and we also don't have the humidity some of you get. Years ago I was wrenching at a Sears Auto center and we had a 73 Cutlass come in for a brake job. It was from the rust belt somewhere. Did a full brake job and the brakes faded badly on it. We brought it back in and measured the rotors and drums again and all in specs. We had rebuilt the calipers and wheel cylinders and all new hardware, shoes and pads and still bad brake fade. Turns out the rotors had rusted inside the vents of the rotors so bad that the rotors were squishing when applying the brakes. Replaced the rotors and whala problem solved. None of us had seen rotors rust from the inside out.
Live and learn.
Live and learn.
Guys and gals, I hate to tell you, but current cars and trucks ( mainly GM, as much as I hate to admit) have severe rust issues with underside components. I see a whole lot of trucks with the brake lines and backing plates corroded so bad they need to be replaced. I'm talking 5-6 years old. GM even has a "brake line kit" that is to be used to replace faulty lines. Sad, it is; very sad.
I’ve had to drive my pristine 07 Grand Marquis for the first time this winter, It has never seen salty roads until this year. It’s the beginning of the end. I don’t have a dedicated winter beater this year.
70 GP SJ Texas car
Rust is still a problem in TX believe it or not and worse if you park it near the coast too long...yikes... You could look through the top of the back trunk window area and see all the way through the car ! and there were lizard eggs in the carburetor
That would be a great NEW thread. I've seen one at the service station while one of my cars was being serviced. There was enough room for the driver to sit -- barely. Every other cubic inch of space in the cabin was occupied by junk, mostly trash, packed so tight it never moved. The mechanic told me of another Hoarder-Mobile where the owned complained his defroster didn't work. The mechanic had to point out that it was because the dash vents were blocked .....
I saw this truck when picking up a pizza last night. I do believe that this is the rustiest vehicle I have ever seen still being driven
My Grand Marquis made it through this brutal winter pretty well. If I don't get my winter beater running for next year I'll spray the prone rust areas with a mixture of linseed oil and Marvels Mystery oil this fall.
Here in Indiana, we used to until the mid 1980's then they quit doing it. Not sure why. (Although I think there are a couple of counties up by Chicago that still require emissions testing)
It had something to do with corruption and no integrity in the system. People were getting their cars inspected, then thought they were perfect still, then something failed, people died, and they blamed the inspection for "certifying it good." No inspection puts the onus back on the owner.
I hate vehicle inspections. Keep your unwashed hands off my cars.
