Round Oil Dipstick?
Round Oil Dipstick?
I was looking through the service manual and noticed the dipstick ID section shows a flat dipstick. The one in my 455 is a round rod looking one. Is this stock? Got to searching the internet some and most appear to be flat? Just curious..
After posting I realized it is flat down where you take the reading, but very narrow, the rest is a rod up to handle.
Maybe I can snap a pic later. Anyway it seems accurate from what I can tell after filling up with fresh oil.
A factory one should be flat all the way up.
Shouldn't be hard to find an original one if you want one (not a high-wear or high-rust item ), but if yours is doing the job, there's no need to.
Thanks Eric. I may look for a factory one because the round one is sometimes hard to take an accurate reading from. Seems to only be accurate on the first pull. At least with the flat dipsticks you can tell easier what is smeared on from inside the tube and what the true oil level is.
The local salvage yards almost never have 455s but I will keep an eye out. Theirs just may be rusty, I've found carbs all full of rain water there before!
dantecl
October 27th, 2013 02:50 PM
