Rocker Arm In Up Position with No Pressure on Pushrod
Old February 16th, 2015 | 09:20 AM
dallasite21's Avatar
I am having a problem with my rocker setup. I have an olds 350, #5 Heads, and I am using the Comp Cams roller tip kit. It seems that I am having an issue where I have tension on the pushrod all the way through the stroke except for a split second when the valve begins to close. The pushrod loses contact with the rocker yet the rocker is still in the up position. I don't understand how that is possible. The springs should keep the pressure on the valve on the way down. If you keep turning it eventually comes down, but will do the same thing on the next cycle. Please have a look at the video, any suggestions would be greatly appreciated.
Olds 350, #5 Heads
Old February 16th, 2015 | 09:21 AM
Sorry.. here is the link if it didn't come through the first time
Old February 16th, 2015 | 10:37 AM
Octania's Avatar
Evidently the valve is siezed in the guide at the half open position.
Correct procedure at this point is to remove the head and inspect everything. Might be a bent valve, or just too tight in the guide.
Old February 16th, 2015 | 10:51 AM
Indy_68_S's Avatar
Can you move the rocker when its in the 'loose' position ? (i.e. Does the rocker move freely ?). If so, what Octania said...
Old February 16th, 2015 | 10:53 AM
don71's Avatar
same but different
I agree, the valve is stuck and the head has to come back off.
Old February 16th, 2015 | 11:22 AM
I cant move the rocker when it is in the loose position... Thing is that it will come down by itself its just at that particular point it allows that separation.. I would think that the valve would never move from that position if it were truly stuck.. I guess either way the head has to come off.
Old February 16th, 2015 | 12:05 PM
Octania's Avatar
well, start by taking that cylinder's rockers off, inspect the rockers for witness marks of binding or interference. Using a suitable pry tool or whatnot, check the operation of the valve/spring w/o the rocker in place. Should pinpoint the problem quickly.
Old February 16th, 2015 | 12:21 PM
Will do. Thanks alot
Old August 27th, 2016 | 05:18 PM
markmag's Avatar
valve
and check out the spring also..I had 1 break last mo...
Old August 27th, 2016 | 08:59 PM
TripDeuces's Avatar
Bent valve? Any way you look at it it's stuck in the guide. Broken spring can do that also but the spring doesn't appear to be at coil bind.
Old August 28th, 2016 | 09:13 AM
edzolz's Avatar
Markmag and Tripdeuces, do you realize this thread is from Feb 2015 ???
Old August 28th, 2016 | 09:17 AM
And that's one of the problems when an OP does not get back and post what the fix was. Newbies will reopen a thread.
Old August 28th, 2016 | 09:36 AM
TripDeuces's Avatar
No I didn't, oh well
Old August 28th, 2016 | 11:05 AM
coppercutlass's Avatar
Chevy budget Olds powered
Are you running adjustable rockers
Old August 28th, 2016 | 11:13 AM
Reread the thread.
Old August 28th, 2016 | 12:01 PM
Looks to me like the rocker is binding on the stud.
Old August 28th, 2016 | 05:19 PM
scrappie's Avatar
I'm hoping he found the problem since the original post is like a year and a half old?
foreverolds
December 1st, 2012 08:07 PM
Cari43
November 20th, 2010 10:21 AM
Cari43
November 2nd, 2010 04:51 AM
millwrightrice
July 28th, 2008 04:26 PM
Slim
Aurora
March 15th, 2007 10:16 PM
Quick Reply: Rocker Arm In Up Position with No Pressure on Pushrod
