revolution per mile
revolution per mile
hi all,
trying to find out the answer to this....how many revolution per mile do the speedometer cable turns? trying to get the right speedometer gear... its a 1968 442 thank you
There is a lot more to know than that. Rear differential ratio, tire size, trans type are just a few. There is a science to it to which one rarely gets it right the first few times. The first place to start is the differential. There is a formula out there for all this. sooner or later someone will respond with that info.
No, there really isn't. The OP asked the revs per mile of the speedo cable that the speedometer is designed to accept. The common GM speedo is designed for 1000 revs per mile on the odometer. Given that, you can do the math for a specific tire diameter, rear axle ratio, and speedo drive/driven gear set to achieve 1000 revs/mile at the cable.
so this number would be most common? I had replaced the old transmission and installed a new tci#211300. Problem is I sold old transmission and I did not take out old speedometer gear and housing. I ask buyer to send pics of old speedo gear so I could count the tooth, so he sent me pics. I counted tooth of speedo gear and I come out with 43 tooth. Color of old speedo gear is light brown, new one with 43 tooth is blue....have they changed colors? Any thoughts out there?
thank you joe, ive got the numbers of the speedo drive and driven gears. based on the rear axle and tire diameter. my problem is speedometer end cable (square) is not mating properly when inserted into the shaft of the new speedometer driven gear. existing speedometer end cable (square) is too small...maybe there is an adapter that's available to correct this problem, or maybe get a new speedometer cable with the correct cable end...
oldspackrat
April 14th, 2014 08:56 PM
Terrifying Toronado
October 18th, 2005 12:15 AM
