Replacing fuel pump on 70-442
Old Feb 23, 2020 | 08:41 AM
capstoneclub's Avatar
I was told to place some grease/lubricant on the arm of the fuel pump prior to installing. Just curious why this is important and do you lube the outside of the "arm" only or should you also lubricate the inside of the inner channel of arm or bracket prior to install? thanks in advance
Old Feb 23, 2020 | 09:01 AM
I suppose the grease is to ensure there is lubrication on the area where the pump arm rides on the eccentric mounted to the front of the cam gear at startup, before the oil pump can push oil to that area. I have never used grease as firing the engine the first time after installing a new pump is about the same as every other time the engine is started in that it will take a bit for the oil to get there.
Old Feb 23, 2020 | 09:51 AM
I don't think its necessary on an engine that has already been run vs a new start up. The eccentric should have oil on it from the last time it was run.
Old Feb 23, 2020 | 10:28 AM
Not to mention the oil galley plug on the side of the camshaft has a small orifice. As soon as the engine starts, oil hits the back of the timing gear and is sprayed everywhere.
A little assembly lube on the fuel pump eccentric is a good idea on a fresh build. Once the engine has been run, it really won’t matter. But won’t hurt if you do add some oil or assembly lube.
Old Feb 23, 2020 | 10:30 AM
Thanks for the feedback guys
Old Feb 23, 2020 | 01:43 PM
I always wipe a little grease on the fuel pump arm where it rides on the eccentric at the front of the cam. The weep hole doesn't spray a lot of oil, and why take the chance of a dry start generating even a few metal filings? Cheap insurance.
330jetstar
Jul 18, 2017 10:17 AM
Tedd Thompson
Jul 13, 2015 06:50 AM
Chris J
Dec 31, 2012 06:43 AM
HonestDave
Aug 31, 2012 01:23 PM
fognozzle
Oct 22, 2011 08:11 PM
