Replace 1972 Oldsmobile Dash
Did you replace the dash to disdribute the AC?
Installing a factory-style A/C system is a LOT of work. You need to remove the front bumper, grills, radiator, dash, and the right front fender. You need to cut the correct holes in the firewall. You need to replace the HVAC boxes on both sides of the firewall, add all the ducting, add the correct control head, add the vacuum hose harness to operate the A/C, swap out the accessory brackets, swap out the pulleys, add a clutch fan, add a larger radiator, add the condenser and plumbing, and then charge the system.
Oldssupreme
Mar 22, 2021 05:01 PM
