removing pistons before crank
this may be a stupid question, but do you have to remove the pistons before taking out the crank? or can they all just slip out at once.
also, what size or type of socket for those nuts.
I usually take the pistons out of the top one by one. I never tried to take em out the bottom and dont know if that is possible....never tried or even thought about it. Surely they cannot come out of the bottom connected to the crankshaft. The Socket for the nuts is a 12 point 9/16
can i engrave them with my dremel and an engraving tool?
how do you label them? is 1 closest to the water pump?
also, why do the rods have to be put in the same?
whats the firing order? or should i say, which pistons are which?
A punch is the quickest way, mark the rod and the cap on the same side so they go together the same way. yes 1 is closest to the water pump on the drivers side followed by 3, 5, and 7, passenger side is 2,4,6,8 again 2 being closest to the water pump. It's a balanced assemby.
It is important to ridge ream the tops of the bores before you remove the pistons. Don't just pound them out with a claw hammer.
Put rubber hose around the bolt shafts so you don't scratch the crankshaft and use a wood or a rubber mallet and a soft piece of wood. If there is any kind of ridge in the bores you can damage the soft pistons when removing them. Don't hit the connecting rod bolts, hit the rod ends.
Delmont 88 PA
Jul 23, 2014 05:19 PM
f-85
Sep 26, 2012 11:18 AM
