Remove A/C
Old Aug 9, 2013 | 01:10 PM
Kotny's Avatar
Remove A/C
Hi, I've removed the a/c on 69 cutlass and just wondering if u can remove I suppose the base which is attached to the actuall engine bay, please excuse the poor car talk I'm new, thankyou
Old Aug 9, 2013 | 01:18 PM
midrange's Avatar
Shaking out the cobwebs..
Yes you can. I used this one on my '71.
http://www.acdelete.com/pages/68-72_A-Body.htm
OPGI also sells one, but I felt it was a bit lacking in the looks department.
Although you have to drill your own mounting holes, it does fit pretty decent. You may also have to grind down a corner of the flapper door frame. That will be pretty obvious to see when you try to fit the plate onto the firewall.
You will also have to cut out/drill a hole for the blower motor relay, that can go anywhere as long as it's in the air flow of the plate.
KRICHEN922
Jul 1, 2010 09:17 AM
t_visker
Dec 29, 2006 08:59 PM
ztim
Oct 9, 2006 05:09 PM
mark5
Feb 18, 2006 04:29 AM
jim braith
Jan 2, 2005 05:48 PM
