Rebuilding a Distributor
Old Jun 17, 2014 | 12:45 PM
Boilerz25's Avatar
I am restoring my 69 442 and would like to restore the distributor to factory specs. Does anyone have a step by step on past rebuilds? Also, if anyone has the NOS cap, rotor, points and condenser that would be great as well.
Sean
Old Jun 17, 2014 | 01:36 PM
Boiler_81's Avatar
The factory shop manual is a good place to start. In addition to the small parts you mentioned you will need to check the bushings, shaft and drive gear for wear. Replace anything which is not to specification. You will also need shims to get the end play within spec. I don't remember off the top of my head what the spec is but it should be in the manual.
Sean
cuttysss
Jan 16, 2014 06:06 AM
chris83
Aug 18, 2012 01:47 PM
staying-old80
Sep 11, 2007 01:23 PM
ijasond
Apr 17, 2007 05:27 AM
<NiN52445>
May 28, 2004 09:45 AM
