Rear Sway Bar
Old Feb 14, 2024 | 07:53 PM
servexcell's Avatar
Rear Sway Bar
I just re-installed the rear sway bar on my 68 convertible Cutlass S. is it normal that it almost touches the underneath of the rear housing
Bruce
Old Feb 14, 2024 | 08:02 PM
Yes.
Old Feb 15, 2024 | 02:41 PM
major tom's Avatar
New but Olds
Definitely makes contact.
Old Feb 19, 2024 | 02:24 PM
servexcell's Avatar
thank you very much for the quick reply
Old Feb 19, 2024 | 05:00 PM
Run to Rund's Avatar
The bar was originally designed with enough bow for the 10 bolt diff. After the 12 bolt became available, later versions with the same part number had more bow in them.
Old Feb 20, 2024 | 05:11 AM
Specifically the smaller 8.2" ten bolt from the 1964 cars. The Type O "12 bolt" isn't appreciably larger than the 8.5" ten bolt.
Old Feb 20, 2024 | 10:31 AM
major tom's Avatar
New but Olds
I like that "12 bolt" comment. 12 bolts on the cover, 10 bolts inside. Changed gears on the posi to 3:55 and I was got off guard. The wonderful world of BOP.
Old Feb 20, 2024 | 10:44 AM
When I mentioned 12-bolts, I was thinking about the "Type C."
Old Feb 20, 2024 | 10:57 AM
Fair enough, Joe
Old Feb 20, 2024 | 12:05 PM
11971four4two's Avatar
MOTORHEAD
Type C
Canadian Cars EH
Old Feb 20, 2024 | 02:03 PM
Type C
Canadian Cars EH
Also Chevelles
Old Feb 21, 2024 | 06:48 AM
BTW, the later version clears the Type F ten bolt pretty well also. Mine uses ten grade 8 1/2x20 bolts which should be pretty good compared to the twelve 3/8 x 16 bolts of the Type C, lol.
Tuffnut
Suspension & Handling
Dec 28, 2021 06:22 AM
edzolz
Apr 16, 2021 04:49 PM
donfitzgerald
May 2, 2015 05:46 AM
willj
Jul 19, 2011 06:49 PM
oldzy
Dec 4, 2010 01:06 PM
