rear end swap
Old May 19, 2014 | 06:06 AM
86odls's Avatar
rear end swap
the other day i was looking around for some lower gears because i have a stock rear end on my 86 cutlass wich is something like a 7.5 2.14 gear rear end and i was wanting to know if i could swap it out for and 8.5 posi trac 3.08 rear end and if 3.08 gears would be worth buying
Old May 19, 2014 | 08:10 AM
oldolds88's Avatar
if the other rear is an 8.5 for a metric car the housing will fit. a body housing is too wide. grand national,monte ss, h/o or 442 metric (g body) will fit. usually the also have 3.73 gears, some posi some not. they are not real common.
Old May 19, 2014 | 10:27 AM
86odls's Avatar
this is what i was talking about
http://www.ebay.com/itm/Gm-3-08-Gear...b97450&vxp=mtr
Old May 19, 2014 | 12:03 PM
oldolds88's Avatar
no they wont fit in a 7.5 housing. if you dont have brute strength in the motor a 7.5 will be fine. find a 80s camaro or s1o,might find a posi in one of those and the 5 sp s 10s usually had 373 gears. 4 spd ones had 342.
350TurBRO
Sep 12, 2014 11:52 AM
oldjunk
Apr 26, 2009 10:26 PM
olds cutlass
Drivetrain/Differentials
Apr 9, 2009 05:44 PM
loosecannon39
Feb 13, 2009 03:34 AM
sscutlas
Sep 4, 2007 10:20 PM
