Rear end opinion wanted
Old Dec 22, 2018 | 06:59 AM
Rvsmith5's Avatar
Just looking to get so reassurance that i am going in an ok direction. I have a 69 442. I swapped in a stock 455. It had a th350 trans, and a chevy 10 bolt with 3.08 gears. I plan to run it for a summer or two as is. I am just curious if the gearing will be an issue.
Thanks,
Bob
Old Dec 22, 2018 | 07:07 AM
Depending on the health of the 455, you may have trans problems a ways down the road if you beat on it. 3.08 was the factory standard ration for automatic 442s that year, so that is how it was intended by default. I don't think you'll hurt that rear with a stock 455.
It will go down the road fine, and it should be good from a stop. It won't be ridiculous, you'd need 4's for that, but it will be fun and reliable.
Old Dec 22, 2018 | 02:19 PM
The gearing is fine, but if you beat it like a rented mule, the trans and that Chevy 10 bolt may not last.
Old Dec 22, 2018 | 06:17 PM
The 8.5 10 bolt is plenty stout. I have a friend with a twin LS 71 Camaro that ran in the high nines with a 8.5 and a spool. He did tear up the aftermarket gears, put the stock 3.08 gears back in to finish the year. The following year he went with a 9 inch.
The TH350 if in good condition will handle some serious abuse with the right parts. At the minimum, install a shift kit. If your rebuilding it, there are some cheap upgrades that will help it live.
Old Dec 23, 2018 | 07:22 AM
Rvsmith5's Avatar
Thanks guys, I think you confirmed that my assumptions and plan are what I hoped. I appreciate you taking the time.
Bob
Old Dec 23, 2018 | 03:06 PM
I have a 71 Cutlass with 2.56 gears which is super doggy off line. I had a 65 Dodge with 3.90 gears which was great off the line but revved too high above 60 mph. I also had a 70 Vista Cruiser with 3.08 gears- loved it. I think 3.08's are a great mostly street use gear.
Old Dec 24, 2018 | 08:33 AM
Eddie Hansen's Avatar
hope so...
Well I am hoping the 3.08s are good with the 455 as I have the bop rear with 3.08s except mine has the m-20 4 speed, that has a lower first gear I understand, fingers crossed.
Old Dec 24, 2018 | 08:44 AM
jcdynamic88's Avatar
eddie,i wouldn't get my hopes up for being happy with the 3.08 with the m20,imo 3.23s aren't even a good match with that trans.3.42 would be good or if you can find maybe a super t-10 that has a lower 1st gear.
Old Dec 24, 2018 | 05:39 PM
The OP has a TH350 trans, 3.08 wont be a issue.
Old Dec 25, 2018 | 07:11 AM
my comment wasn't for the op,it was for eddie hansen who posted before me as was evidenced by me addressing eddie at the beginning of my post
Old Dec 25, 2018 | 07:42 AM
sorry, didn’t notice his name in your reply. I hang my head in shame
Old Dec 25, 2018 | 08:25 AM
Kennybill's Avatar
You didn't say if it was a posi or not. Either will hold up fine unless you do the burnout circles like the jackass' do on TV. If you do burnouts, straight line only. Slicks can be hard on the spider gears after a while. I'd take a 8.5 with bolt in axles over a corporate 12 bolt C clips every time.
Old Dec 25, 2018 | 08:28 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
The M20 has very close to the TH350 for gearing. The M21/22 is different with a 2.20 first gear.
Old Dec 26, 2018 | 07:02 AM
Rosie39j's Avatar
The thread title “Rear end opinion wanted” sent me into auto response mode of “oh no dear, you look great.’ ��
Old Dec 26, 2018 | 02:54 PM
now that is funny
Old Dec 26, 2018 | 03:02 PM
11971four4two's Avatar
MOTORHEAD
# 3.08 ratio will work fine with m20 and / or TH350
Old Dec 26, 2018 | 06:18 PM
Rvsmith5's Avatar
now that is funny
agreed!
BlueBeast
Drivetrain/Differentials
Jan 8, 2016 01:23 PM
tnwheelgunner
Mar 10, 2015 09:34 PM
Chevydude9219
Nov 1, 2014 08:18 AM
bigjaythe1st
Jun 20, 2012 12:39 PM
Jacoz70442
Feb 24, 2011 12:40 PM
