Rear End
Old May 26, 2020 | 06:52 PM
sherlock1212's Avatar
Rear End
I have a 68 olds cutlass s. It has a single axle I need to know how many spleens it would have Any help would be grateful thanks
Old May 26, 2020 | 07:19 PM
JohnnyBs68S's Avatar
I'm assuming you are describing a "single wheel peel" (non-posi) rear end (not that it matters, because it doesn't).
If it is the original Type-O axle (12-bolt cover / 10-bolt 8.5" ring gear), it'll most likely have 28 spline axles. 31 spline axles were used with higher numerical ratios (4.xx+). If you check the axle code stamped on the passenger side tube (careful cleaning sometimes required to find it), you'll know what is in it if it hasn't been rebuilt / modified.
rcdynamic88
Drivetrain/Differentials
Nov 23, 2017 08:43 PM
BackInTheGame
Jun 8, 2013 07:50 AM
lil_no
Jan 27, 2012 08:33 PM
jag1886
Jan 4, 2011 12:08 PM
OLD SKL 69
Jan 24, 2008 08:36 AM
