Rear Axle Flange
What do you mean by "rear axle flange"? If you're talking about the wheel bolt pattern, yes, they are both 5 x 5". The flange itself is part of the axle shaft, and the shafts are different because the axles are different types between the two years. If you are talking about the rear axle pinon flange, those are also different.
what do you mean by "rear axle flange"? If you're talking about the wheel bolt pattern, yes, they are both 5 x 5". The flange itself is part of the axle shaft, and the shafts are different because the axles are different types between the two years. If you are talking about the rear axle pinon flange, those are also different.
HitTheHole
Drivetrain/Differentials
February 4th, 2021 10:46 AM
Chesrown 67 OAI
October 27th, 2010 05:56 PM
oldzy
September 27th, 2010 05:49 AM
