ready to start
Old Jun 3, 2013 | 06:52 PM
hawks70's Avatar
ready to start
Well, tried starting the Cutlass today. Not running yet. I think I may not have a good ground on the block and the battery just needs to be replaced. We will check and take care of these two things tomorrow morning and try again.
Old Jun 3, 2013 | 07:11 PM
don71's Avatar
same but different
Good luck, and looking forward to your updates.
Old Jun 3, 2013 | 08:32 PM
Good luck, let us know how it goes.
Old Jun 4, 2013 | 08:45 AM
hawks70's Avatar
Signs of life. Sort of. Backfiring. Time to play with distributor.....
Old Jun 4, 2013 | 12:08 PM
Double check your wiring firing order, and if it's back firing and flaming through the carb, it may be 180 out.
Old Jun 4, 2013 | 01:10 PM
hawks70's Avatar
Charging battery. Needs a long charge. Been sitting a long time. Its taking a charge tho. While that's doing its thing must bleed brakes cause I didn't bleed the lines after new master cylinder installed and gonna fabricate a egr block off plate....
Old Jun 10, 2013 | 02:29 PM
hawks70's Avatar
Update. Timing was 180 degrees out. Got it to fire today but had to shut it down after very short time due to fuel leak on carb. Shut it down and pulled carb. Fixed that problem and put carb back on. On next try my yellow wire that goes from starter to distributor caught fire somehow. I know no gas got down there so no idea. Got to pull starter back out and check the wires to see if I can repair....
colemane
Apr 13, 2013 01:19 PM
Destructor
Oct 22, 2010 05:35 PM
rrielley
Sep 1, 2008 03:00 AM
Cardoc
Nov 20, 2007 09:04 AM
84cutty
Sep 8, 2006 12:32 AM
