Rare intake
Old Sep 1, 2018 | 06:17 AM
marxjunk's Avatar
Rare intake
Saw this on Facebook..covers say sharp equipped and Hurst Olds
Old Sep 1, 2018 | 07:45 AM
Hairy Olds's Avatar
Shoveling Snow
There out in the wild. About a dozen were made.
Old Sep 1, 2018 | 09:17 AM
I know where at least two of them are...
Old Sep 1, 2018 | 09:29 AM
Hairy Olds's Avatar
Shoveling Snow
Lansing correct.
Old Sep 27, 2020 | 05:58 PM
Funkwagon455's Avatar
I’ve seen the car and had the pleasure to meet the creator on several occasions, although it has been just a while. He ultimately went to a dual quad setup, but even practical folks like myself have to smile at the sheer “over-the-top” notion. Truthfully, I’d like to have the intake purely for a conversation piece if nothing else..
Old Sep 27, 2020 | 06:49 PM
bccan's Avatar
Sorry if I’m sending this thread awry - Re: Quad Quad (I do love that thing)
1) The mist that develops above the carbs, is that some sort of reversion or is it condensation or is it something else?
2) Why do the secondary air flaps stutter instead of smoothly opening?
That blower manifold is nice, if you had one of those it sure would save some work machining something else.
Old Sep 27, 2020 | 07:15 PM
Apologies folks, I’m two for two today as far as info-f$&@k ups! I was thinking of another crazy intake thread. Maybe I need to get some rest..
Old Sep 28, 2020 | 03:02 PM
TripDeuces's Avatar
He's venting fuel because of the open tops. Creates a low pressure area above the carb and suction happens. You can even hear it change when it happens. Put a box around them or air filters and that will stop as long as the lid is far enough away from the air valves or the bowl vent.
Old Sep 28, 2020 | 03:27 PM
deadeyejedi's Avatar
bad *** setup ! , but tell me what is the modern way to go in order to dump the amount of fuel that thing is dumping
Old Sep 28, 2020 | 04:07 PM
Schurkey's Avatar
Two symptoms of the same problem. The intake air stream is reversing due to the sonic tuning of the Independent Runner (IR) manifold. The fuel / air mix blowing backwards out of the carb has been through the venturis twice, it's extra-rich--and the air motion plays hell with the air valve which wasn't designed to flow air backwards.
A box around the carb inlet would contain the fuel mist, but it wouldn't stop the creation of the fuel mist. The fuel mist is due to the intake construction--no plenum, each cylinder has it's own primary and secondary "barrels".
Every time the intake valve shuts, it sends a "ram-tuned" positive-pressure wave back out of the carb, carrying a "double load" of fuel with it, and in the process, it's interfering with the smooth operation of the air valve.
CONTAIN the fuel fog, and that air/fuel mix goes back down the carb AGAIN, picking up even more fuel. The Q-Jet design is unsuitable for this application--I don't know how you'd fix the air-valve problem, or lean-out the mixture so that three trips through the venturis gets just the right amount of fuel.
Old Sep 29, 2020 | 08:46 AM
Run to Rund's Avatar
According to the August 66 Car Craft, the long ram Mopar intake tuned for 3000 rpm and then later the engineers found they could tune for higher rpm with a shorter ram, and get a secondary effect at half that rpm. Same issue of CC that covered the 66 W30 conversion at Hurst Performance on Dave Landrith's car. If you look at the photo of the short block closely, you can see it has a D cast in the side of the"400" so Dave actually used a 425, probably a Toro engine so it would take .921" lifters and a 39 degree cam like the 400.
Old Sep 29, 2020 | 08:56 AM
That's great! I remember articles about mushroom lifters to get a larger effective lifter diameter to better use the cam lobe profile. I'm assuming the block was sleeved to get the 4.000 bore?
BOOWAH
Jul 3, 2019 04:28 PM
madmax442
Jan 6, 2019 01:42 PM
Rocket 78
Nov 20, 2018 11:21 AM
Troys Toy 70
May 12, 2016 08:24 PM
RATT
Mar 24, 2007 10:28 AM
