Rag joint grounding wire.
Old Mar 10, 2023 | 08:46 AM
Redbud40's Avatar
I bought a new one and it does not have the wire. The original wire was placed under the large rivet built in.
What is this grounding and can I install without?
Thanks.
Mike
Old Mar 10, 2023 | 10:27 AM
The horn button grounds through the steering shaft. Without the wire, the rag joint is an insulator and the horn may not work or may work poorly. I just made up a short length of wire with two ring terminals and put it under the bolt heads on either side.
Old Mar 10, 2023 | 11:44 AM
Redbud40's Avatar
Thanks Joe. Done. On to the vacuum mystery.
2blu442
May 28, 2020 06:58 AM
friesjh
Sep 18, 2019 07:09 PM
F85 330 ctls
May 29, 2019 10:31 AM
Icee5150
Sep 1, 2013 10:16 AM
stingger68
Mar 2, 2010 04:12 PM
