Radiator dimension please..
Old Sep 1, 2024 | 07:24 AM
Tancuda's Avatar
Hi everybody,
for a 71 442, No AC, does anyone have the dimension as shown on the picture for an original 2-3 row radiator, looking for a good fit replacement one.
At least the core height and width would be great to have.
Old Sep 1, 2024 | 10:26 AM
redoldsman's Avatar
Proud Viet Nam Veteran
I just installed a Cold-Case aluminum radiator in my 75 Hurst Olds. It is listed as fitting a 71 also. It was a perfect fit. The only thing I had to do was move the top transmission cooler line up a little which was no problem. It made about a 20=25 degree difference in my operating temperature.
Old Sep 1, 2024 | 11:15 AM
Tancuda's Avatar
Thanks a lot redoldsman for the comment, I was leaning towards a cold case too (they have a black finish one also), the core is 18 x 28 or 18.5 x 28.7 but I don't think it will make a huge difference. They have different lower hose diameter though.
Any leaking at the cooler lines line on rad ? Steel fitting in aluminium !
Thanks again
Old Sep 1, 2024 | 02:26 PM
redoldsman's Avatar
I don't know if they were steel fittings in aluminum or not but no leaks. I did quite a bit of research on aluminum radiators and although Champion is a lot less, they are for sure cheaper with lots of problems leaking in a couple years. Griffin is way more expensive and in my opinion, not worth nearly twice the price.
Old Sep 1, 2024 | 03:32 PM
cdrod's Avatar
Rodney
I have a Champion CC161 radiator with dual 13" Derale electric fans and shroud. I had some fit issues with the Champion radiator because the core was not square preventing the shroud from fitting properly. The core measures 28.25"x 17"x 2.25" thick with 3-rows of 5/8" tubes. I don't have many miles on my car since the restoration but engine temps so far have never exceeded 220 degrees in 98-degree weather (running a 180 degree thermostat and no AC).
Here's a pic of the out-of-square core.
Rodney
Old Sep 1, 2024 | 05:04 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I have the original recored copper brass two core that blew out. The Autocity 1 1/8" dual core fit great, cools really well and has stamped tanks like the Cold Case in my 70 Cutlass S.
https://www.ebay.ca/itm/351157989603...mis&media=COPY
Old Sep 2, 2024 | 07:26 AM
Tancuda's Avatar
Thank you all
72Vert442
May 30, 2024 12:40 PM
bluecutlassconv
Apr 22, 2016 06:34 PM
Stevec
Jun 8, 2012 09:27 AM
L69
Apr 27, 2012 05:46 AM
Texas442
Dec 8, 2010 08:16 AM
