Questions about my exhaust manifolds
Old October 10th, 2012, 08:14 PM
1970 Cutlass Convertible
red130's Avatar
I started cleaning up my exhaust manifolds with my new blasting cabinet and saw that one had been beaten up with a hammer. What would be the best way to fix this without smoothing out the finish? (if any)
The right side manifold doesn't seem right to me...
Last edited by red130; October 10th, 2012 at 08:43 PM. Reason: edited for clarity.
red130 is offline
Old October 11th, 2012, 04:34 AM
69442C's Avatar
The marks you have on that manifold is not from abuse but rather normal rust over the years. This is common to see. While I have never used it, there is a product called Pyro Putty this is designed for repairing exhaust manifolds and it seems it would work well for your repair. Google it to get more info on it. You would need to do a little experimenting with it to duplicate the cast look but one way may be to let it cure, final sand it and then use a small punch and hammer to dimple the surface.
You would need to post your application to get input on the other manifold being correct or not.
Brian
69442C is offline
Old October 11th, 2012, 10:30 AM
red130's Avatar
Thanks for your reply... I will look into Pyro Putty. My car is a 1970 Cutlass Convertible with a 350 engine.
69442C, I love the 442 you're doing. World class work that I will be working to duplicate.
http://www.aremco.com/product/a15/
red130 is offline
Old October 11th, 2012, 05:16 PM
69442C's Avatar
Thanks.
I'm not sure about the pass side manifold so if you still have doubts, post another thread with that question or maybe someone else will see this and respond.
Good luck with your car.
Brian
69442C is offline
Old October 11th, 2012, 06:26 PM
72 Olds CS
RetroRanger's Avatar
yeah my pass side exhaust manifold looks very similar to that. 72 350 sbo
They sell a block off plate for the cross over tube FYI
RetroRanger is offline
Old October 11th, 2012, 07:43 PM
Octania's Avatar
Really?
That's what we call "negligible rust pitting" in MI. no HOLES THRU? it's good to go. Maybe you can get the NOS ones available recently from the Vendor Who Must Not be Named. Or Thornton's repro true-duals SB manifolds. New and pretty.
You guys down south....
Octania is offline
Old October 11th, 2012, 10:23 PM
Originally Posted by Octania
Really? Maybe you can get the NOS ones available recently from the Vendor Who Must Not be Named. Or Thornton's repro true-duals SB manifolds. New and pretty.
Really. Olds never ever made a 350 'true' dual exhaust manifold for the 68-72 Cutlass. It's a shame too since it's a great engine. All the 350 powered Cutlass models with the N10 exhaust had the p.s. manifold blocked off with a filler plate. Same as you can do at any muffler shop.
Just a heads up on the Thornton product. I've corresponded with people who bought those when they first came out because I was thinking about them too. The word to describe what you call "Thornton true duals" would be underwhelmed. They are new and pretty indeed. They also do not have any GM markings or casting numbers. They do however have castings that Identify them as Thornton manifolds.
Thornton says they have corrected the flaws in the original casting on the center web area.
Allan R is offline
Old October 12th, 2012, 06:52 AM
MOTORHEAD
11971four4two's Avatar
Here is a picture of a factory small block dual exhaust block off plate on pass side manifold
11971four4two is offline
Old October 12th, 2012, 07:13 AM
red130's Avatar
Thanks for the picture, is this for your 1971? What would be the purpose of the 'dual' outlet on the passenger side?
red130 is offline
Old October 12th, 2012, 07:22 AM
MOTORHEAD
The manifold was removed from a 72 442. 71 442 came with 455 and the W and Z "bigblock" exhaust manifolds.
The "dual outlet" is where the cross-over pipe from drivers side attaches in a single exhaust application.
Old October 12th, 2012, 08:51 AM
That was the only exhaust Olds made for the 350. So it had to serve 'dual purpose' no pun intended. The majority of Cutlass produced were single exhaust so it was probably easier to just produce one ex manifold for mass production.
Allan R is offline
bulky
August 28th, 2006 11:59 AM
bulky
July 20th, 2006 12:56 PM
linas9
February 23rd, 2006 01:10 PM
EdsDelta
July 22nd, 2004 11:46 AM
copper128
March 21st, 2004 09:43 PM
Quick Reply: Questions about my exhaust manifolds
