Question about Edelbrock intakes for a 66
Old Jan 3, 2016 | 08:27 AM
Mr442's Avatar
I did a search for this and found some stuff about the 68 to 72. However, nothing on my 66.
Question...I have a 455 in my 1966 442 and I am looking to put a Performer intake on it. According to their website, it states it will not fit under the hood for 64 to 67 applications. Has anyone every tried this and is there anything that can be done to utilize the stock hood? Can you shave the carb pad?
Old Jan 3, 2016 | 08:29 AM
The regular Performer should fit fine under a flat hood for a 66.
Old Jan 3, 2016 | 01:23 PM
RAMBOW's Avatar
Ben
You'll need a drop base air cleaner, but those are easy and cheap. You may already have one.
I had a torker intake on the 455 in my 66 and it fit(barely) and the torker is taller than the performer!
Old Jan 3, 2016 | 04:26 PM
fleming442's Avatar
I've had a Performer and Torker on my BB 67 with no issues.
Old Jan 3, 2016 | 04:58 PM
CRUZN 66's Avatar
Olds Fever
I had issues with a Torker on my 66....
Old Jan 4, 2016 | 04:41 AM
lemoldsnut's Avatar
It just clears. We had ours on for some time with the inner fenders out as we did some body work and such and could see it very clearly. I used the factory drop open element air cleaner base with a short air filter and a K&N filter top and no hood pad and got great air flow and no clearance issues.
Old Jan 4, 2016 | 05:16 AM
If you need extra clearance and are NOT using an Ebrock carb, this will work on a Rochester or Holley.
http://www.ss396.com/chevelle/ATE-3907.html
Old Jan 4, 2016 | 09:52 AM
oldsmobiledave's Avatar
Hood Clearance
I have had both Torker & Performer on a BBO in a 65 442 and in a 66 Cutlass with no issues.
Old Jan 4, 2016 | 08:49 PM
Mr442's Avatar
I think I will be ok... Thanks Everyone! I appreciate it!
Old May 11, 2021 | 01:07 PM
sgolds's Avatar
I’ve had nothing but trouble with q jets, especially with the threads in the inlet getting stripped and leaking. Rebuilt or not, I’m just so sick of all the issues they have that I wanted to try something else, but apparently not much else will fit I guess
Old May 11, 2021 | 01:27 PM
You're doing something wrong. I haven't experienced any issues with the QJets on my cars, and I've been wrenching on them since the 1980s.
Old May 12, 2021 | 05:42 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
It must have to do with the early, smaller inlets. Yeah, 0 issues on many 76 and up carbs. There is a reason Cliff and others build the 76 and later carbs for high performance, Rochester improved them over the years, much of it was for reliability. The APT and larger primary castings were just a bonus. That is another thing I like about my 70 over my G body, the "S" provides a lot of room especially with a 350. The hood weighs a freaking ton compared to my 88 and no doubt much heavier than a flat 67 hood.
69CutlassAlex
Jul 30, 2013 08:18 AM
olds 307 and 403
Jan 11, 2012 03:39 PM
70Cutlass_408
Jun 24, 2011 07:55 AM
Aceshigh
Oct 22, 2010 11:03 PM
B.O.P. Connection
Oct 29, 2004 11:34 PM
