Q/Jet Question
Old Dec 4, 2020 | 08:29 AM
Fazer's Avatar
Q/Jet Question
I took the 69 to the quardajet guru. After he looked at it, he told me that is not the right carburetor for the car. It seems it's from an 86 or 84 , (can't remember which), Chevy. He reckoned the newer carbs aren't as good as the older ones. He also told me that it has been messed with, efforts made to increase the performance. Not totally sure what he meant by that. We will have to see what happens. Any thoughts on this. Thanks
Old Dec 4, 2020 | 08:38 AM
Without knowing the carb number of your current carb, it's difficult to provide a useful comment. Mid-80s Chevy truck carbs have the same front inlet as do most Olds carbs.
Here's a listing of the correct 1968-1970 carb numbers.
Old Dec 4, 2020 | 10:08 AM
4speed455's Avatar
Cliff Ruggles, the guy who literal wrote the book on quadrajets prefers the 1705 series carbs from the late 70 and early eighties with modified idle circuits and metering rods for performance builds. They later eighties computer controlled carbs are not ideal however. Depending on the number that carb may not be correct but it might work really well if tuned correctly. You can call Cliff and give him the carb number and your engine specs and he can recommend a tuning package for your application. He also sells quality parts and a good price.
Old Dec 4, 2020 | 10:32 AM
Here is Cliff's book:
Amazon Amazon
I also have the one by Doug Roe:
Amazon Amazon
They're both excellent resources.
Old Dec 4, 2020 | 10:38 AM
4speed455's Avatar
You can also join his forums to post questions or order parts online on his website. https://cliffshighperformance.com/
Old Dec 4, 2020 | 12:07 PM
dragline's Avatar
A picture would help a lot. Did your guru give you a part number? It's not good to bolt on an emissions legal carb like a quadrajet without upgrading the fuel circuits.
Old Dec 7, 2020 | 05:22 PM
Fazer's Avatar
I have been away. The carb number is 17084226, out of a Chevy truck by the looks of it.
skyhigh
Oct 12, 2020 10:27 AM
Bozang1
May 3, 2015 06:11 AM
ELECMAN
Oct 6, 2009 12:38 PM
ijasond
Jul 28, 2009 12:47 PM
Southern_Hospitality
Jul 15, 2009 12:27 PM
