power steering pump
power steering pump
not sure which power steering pump to buy for my project .im putting a 74 toronado 455 into a 80 cutlass and need to get a power steering pump.i have all the original pulleys and brackets for the 74 but not the pump and reservoir .could i disconnect the pump and reservoir from the 1980 307 olds motor in the car now and simply reconnect it to the 455 brackets? or will the lines from a 74 toro pump connect up to the 1980 steering box ?ive checked rock auto and get different part numbers for each application .thank you
197064buickspec
July 1st, 2014 03:08 PM
