power steering pump
Old Jan 12, 2019 | 04:47 AM
deadeyejedi's Avatar
power steering pump
not sure which power steering pump to buy for my project .im putting a 74 toronado 455 into a 80 cutlass and need to get a power steering pump.i have all the original pulleys and brackets for the 74 but not the pump and reservoir .could i disconnect the pump and reservoir from the 1980 307 olds motor in the car now and simply reconnect it to the 455 brackets? or will the lines from a 74 toro pump connect up to the 1980 steering box ?ive checked rock auto and get different part numbers for each application .thank you
Old Jan 12, 2019 | 05:35 AM
All the Saginaw pumps have the same pump body. Only the sheet metal reservoir differs from year-to-year and application-to-application. Use the 1980 pump, brackets, and lines. This will all bolt to the 455. Just be sure to use the spacers in the right places.
Old Jan 12, 2019 | 08:35 AM
thanks again joe
Classics65
Aug 22, 2016 05:09 PM
csouth
Oct 16, 2015 09:05 AM
yalikeme
Aug 16, 2015 08:59 AM
197064buickspec
Jul 1, 2014 03:08 PM
sweet70oldz
Brakes/Hydraulic Systems
Jun 30, 2012 01:21 PM
