Power steering filter.
Old May 24, 2025 | 10:39 PM
GCH's Avatar
GCH
Hi , anybody who using inline filter to the power steering return line ? Replacing the pressure hose now and
seen the oil looks dirty fast. Same in my Saginaw pump in the GMC , that canister had a magneto to the wall of
the canister.
Old May 25, 2025 | 04:33 AM
My 86 Ford F250 has a 6.9l IDI diesel and it has an OE power steering cooler. I've never heard of installing a filter in the low pressure power steering hose. 🤔
Old May 25, 2025 | 06:11 AM
GCH's Avatar
GCH
Here is one model :
Amazon.com: Magnefine 3/8" Magnetic Inline Transmission/Power Steering Filter : Automotive Amazon.com: Magnefine 3/8" Magnetic Inline Transmission/Power Steering Filter : Automotive
High-Quality Power Steering Filters | Magnefine Filters
https://youtu.be/bI8prgz2qjo
https://youtu.be/9jqDfLQeEcI
Old May 25, 2025 | 08:10 AM
GCH's Avatar
GCH
One more :
Old May 25, 2025 | 09:00 AM
In over half a century of driving GM vehicles, I've never used nor felt the need for a PS filter. Sounds like a product trying to create a market. And frankly, I'd be concerned that any filter fine enough to catch particles that matter is probably a restriction in the system that can reduce flow.
Old May 26, 2025 | 09:30 PM
GCH's Avatar
GCH
Never heard of somebody using PS filter here in Sweden either , maybe change the fluid sometimes instead.
Old May 27, 2025 | 01:36 AM
I had a Mercedes W123 wagon that had a power steering filter. Changed it once in the short time I owned the car, don't know if it did any good. But, you know, it was a Mercedes.
Old May 27, 2025 | 02:46 AM
GCH's Avatar
GCH
Yes Mike , the ps fluid looked bad so if a filter catch
particels instead of these going around in the system the whole time is a good thing.
Have worked a little with hydraulic system in the industri and clean oil in the system is important.
Old May 27, 2025 | 05:32 AM
Sugar Bear's Avatar
Had several W123 and W124 Benz's, all had filters from the factory and they would catch debris. Are they necessary? Maybe, maybe not. Haven't seen them in any other vehicles, has anyone else?
Old May 27, 2025 | 05:42 AM
70sgeek's Avatar
'72 Cutlass ragtop
Can you better describe how quickly you're noticing the PS fluid get 'dirty'? What are you actually seeing in the fluid that makes it dirty (i.e. change in color, actual shavings or debris on the pump canister magnet, etc.) ?
What kind of fluid are you using, how old are the gearbox and pump? Are you getting any PS system noise?
Could be a number of variables here in play to account for what you're seeing, and/or be suggesting time for an equipment replacement beyond just the hoses rather than an external filter.
Old May 27, 2025 | 07:32 AM
GCH's Avatar
GCH
The Saginaw pump in my GMC was leaking so i had it apart and there was a lot of particles on the magneto
and the canister walls need also to be cleaned to before mounting together , but the fluid was not so dark probaly
to the leaking for a while and refilling with atf fluid. Don´t know how often the previos owner changed oil.
When i took off the hoses of the Olds pump now the oil was dark and the car have not run so much since i changed
the oil last time , have no idea how it look inside the pump canister , but ps works fine now.
I had to replace the PS pump in my 88 because it siezed up so bad that the belt jumped. The canister
needed to be cleaned inside at the same time , so that,s why i was thinking on a filter for saving pump
and steeringbox to maybe last longer.
Using Dexron III in all PS and automatic transmissions , no noise in the PS system for now.
Old May 27, 2025 | 12:48 PM
70sgeek's Avatar
'72 Cutlass ragtop
I dunno - I'd flush the whole system out and refill with a good synthetic PS-specific fluid..
57J2Olds
Jul 8, 2022 05:14 AM
68442
May 18, 2022 07:37 AM
Reese Neis
Jul 4, 2021 01:03 PM
coled18
Apr 7, 2021 04:56 AM
EightyEightCut
Sep 29, 2012 10:20 AM
