Power brake Vacuum hose
Old Feb 24, 2026 | 01:50 PM
68442's Avatar
1966 442
This may seen trivial to most, however, Is there anything unique to the Vacuum hose for power brakes on a 66 442? Any Ribs,markings, etc. Looking for assembly line correct. If so who is reproducing a good example?
Old Feb 24, 2026 | 05:34 PM
Are you referring to this vacuum line?
https://www.inlinetube.com/products/...gn=sag_organic
Old Feb 24, 2026 | 05:49 PM
70Post's Avatar
He's asking about the vacuum hose to the power brake booster.
Old Feb 25, 2026 | 04:15 AM
jensenracing77's Avatar
If it is anything like 62 and 63 then it has SWAN ink stamps about every 6 inches. Ours are not ribbed but has a larger OD (thicker wall size) than a typical vacuum line. Not sure if it applies to 1966 or not.
Old Feb 25, 2026 | 10:21 AM
Jungle Cat's Avatar
Go to NAPA and tell them you want vacuum brake hose. That will make sure you got the correct stuff with correct thickness. It’s DOT rated. Don’t use fuel hose. Also by 70-72 they were using black pinch clamps. So many supply red or green sized. That is just not correct. I don’t know what cosmos ore 70 used.
Old Feb 25, 2026 | 11:55 AM
F-85 4-4-2's Avatar
I bought this. May not be factory correct, & made in Mexico, but I trust Gates.
Amazon.com: Gates 27232 Power Brake Vacuum 11/32 inch x 36 inch (85 PSI) Hose : Automotive Amazon.com: Gates 27232 Power Brake Vacuum 11/32 inch x 36 inch (85 PSI) Hose : Automotive
nicks1966
Sep 4, 2023 04:36 AM
Koda
Brakes/Hydraulic Systems
Jun 29, 2022 09:48 PM
skiflyer
Aug 2, 2021 11:08 AM
l6conv
May 6, 2021 03:48 PM
harleyrules
Nov 16, 2007 05:27 AM
