Powder coating
Old Oct 19, 2011 | 08:38 AM
kjr442's Avatar
Kjr442
Powder coating
I have the powder coating bug! I powder coated my frame first,and things just got crazy after that.
I am now starting my engine build. I have cleaned most of the parts that will be powder coated, and will remove any existing paint.
I know all of the brackets will be fine to coat,and some of the other under hood parts,but what about the pulley's? Can the pulley's be powder coated? how would you coat just the outside part of the pulley,and not coat the belt area? Has anyone else been through this?
Old Oct 19, 2011 | 09:01 AM
Tony72Cutlass'S''s Avatar
I am very curious about the pulleys too. I will be either powdercoating or painting mine soon.
Old Oct 19, 2011 | 09:12 AM
firefrost gold's Avatar
ram air resteration sells power coated pullys
Old Oct 19, 2011 | 09:38 AM
RALLYE KID's Avatar
My pulleys are powder coated no problems!!!
Old Oct 19, 2011 | 10:40 AM
Any pictures of the finished product??
Buddy of mine has a place i can send them to for a reasonable price to get em' powdercoated black.
Old Oct 19, 2011 | 11:27 AM
http://www.extremepowdercoating.net/ has anyone done their block or heads ?
Old Oct 19, 2011 | 02:08 PM
MX442's Avatar
I had mine powder coated. No problems. Here's the best picture I could find.
Old Oct 19, 2011 | 02:28 PM
Aceshigh's Avatar
Damn near anything and everything can be powdercoated.
I just got my front core support, hood hinges, and rad cover back from being blasted , torn apart and PC'd.
It's IMO the best way to keep a car lasting damn near forever if done right.
I'd powdercoat the entire body if I could.
If Auto manufacturers did this, the body's would outlive the drivetrains.
Eventually I'm going to pull the body off, blast and PC it and then run all new brake lines and body bushings.
I just don't know where I'm going to take it to get this part done just yet.......
Old Oct 19, 2011 | 02:57 PM
How Many miles are on it ? Does it look that nice still?
Old Oct 19, 2011 | 05:18 PM
mike's88's Avatar
I just had mine done, as an afterthought, I had the same question. If you don't want the grooves done, the coater can run a strip of silicone tape in them. The powder won't stick there, and it holds up to the temps used for it to flow out and cure. Aces, are you talking about doing the body, or the frame?
Old Oct 19, 2011 | 06:27 PM
kjr442's Avatar
Kjr442
Still looks good? I am concerned about the belt notch/groove. How long have you had it in service with the coating in the groove?
Old Oct 19, 2011 | 06:31 PM
kjr442's Avatar
Kjr442
Originally Posted by Aceshigh
Damn near anything and everything can be powder coated.
I'd powder coat the entire body if I could.
If Auto manufacturers did this, the body's would outlive the drive trains.
I just don't know how long the coating will hold up with the belt riding on it.
Old Oct 19, 2011 | 06:33 PM
kjr442's Avatar
Kjr442
Even in the belt groove? If so, how long has it been in service/ or how many miles?
Old Oct 20, 2011 | 03:35 AM
MX442's Avatar
Yes, even in the belt groove. Don't worry about it.
I drove it for about a year, 300 miles or so, and sold it. The belt never wore through the PC. I'm sure it will eventually wear through, like your factory one. I wouldn't worry about it though. It had no effect or slippage on the belts. I will be doing the same on my other car.
Old Oct 20, 2011 | 03:54 AM
RALLYE KID's Avatar
Cars been in service for about 10 years. That powder coat is like concrete you will never hurt it.
Old Oct 20, 2011 | 04:44 AM
Hey Kid what is the coating on the bumpers of the famed screaming yellow zonker?
Old Oct 20, 2011 | 05:00 AM
RALLYE KID's Avatar
If your talking to me about About my Rallye 350's bumpers its the rubber coating and sebring yellow code 51 Just like it came from the factory!!!
Old Oct 20, 2011 | 06:39 AM
Yes how do they put it on and Do you think it would make a good underbody coating ? Seems to hold up well ?
Old Oct 20, 2011 | 07:16 AM
RALLYE KID's Avatar
You spray it on with a gun. Most paint shops don't carry this because of EPA reasons.
Old Oct 20, 2011 | 09:07 AM
stevengerard's Avatar
You spray it on with a guy. Most paint shops don't carry this because of EPA reasons.
I prefer to use a women instead of a guy - just my preference
Old Oct 20, 2011 | 09:16 AM
X2, bring on the ladies with paintguns
Old Oct 20, 2011 | 06:52 PM
Aceshigh's Avatar
The reality is the belt grooves have constant pressure and friction running
across them to clean up whatever corrosion built up if the car is driven routinely.
Unless the car sits for eon's, with alot of imperfections in the PC'ing it will be fine.
Inside the grooves is the least of your worries tho.....
Alot of these cars have 40-50 year old pulleys on them.
Just blast them and clean them and many are still like new.
So a powdercoat is just going to help them live even longer.
I personally need to do my frame(s)
But I was also stating that if Auto Manufacturers would PC their body panels and fenders the cars would last forever.
Old Oct 21, 2011 | 05:15 AM
RALLYE KID's Avatar
Just a typo I fixed it. Don't get any ideas!!!! stevengerard
Old Oct 24, 2011 | 05:51 AM
kjr442's Avatar
Kjr442
Ok guy's thank you for the advise. I have all my parts cleaned and stripped of any old paint. I will be taking everything ( pulleys too) to Cross link powder coating some time this week.
It is nice to be able to bounce things off other guys that have been through this before, thank you.
BigTrav
Feb 27, 2011 11:20 AM
andrew.minarick1
Nov 3, 2010 07:34 PM
shovel55
Oct 24, 2010 05:09 PM
Wilson05
Brakes/Hydraulic Systems
Jan 7, 2010 12:16 PM
blonzz
Oct 25, 2004 02:19 PM
