Post moved from General forum
Here we go again, I place a general question about brake fluid and it gets moved. I put it in the General section to get the most replies and advise that I could.
Currently there are 10 posts about Cutlasses in the General forum, why haven't they been moved to the Cutlass forum.
Are you going to create a "BITICHIN" forum to move this to so that no one sees it.
If I had to guess..a specific question such as brake fluid NOT being in the "brakes section would warrant the move. If it was a generalized question that, amongst the conversation had brake fluid brought up, then I would see warranting it staying in the "general" section.
At least that's how it was when I was heavily active in other forums and in constant communication with those admins.
The easiest way to see a post is click new posts and they all come up, it doesn't matter what forum. That's what I do when I come on.
If it's an interesting topic, folks will see it and respond or not. When I leave, I mark forums read under the quick links tab so there are not 6 dozen
to read when I come back on. Works well for me anyway. Good luck with the bitching thing though, that might not work out as well.
Damn if its about brakes it goes in the chassis brake forum..why is that a problem? If everyone used general discussion for everything “ so they maximize views” then boy would that be a damn mess.. as one user stated, use new posts like many of us do..relax brother…its only cars
Pat55Olds
Site Help
November 30th, 2020 04:58 PM
