Possibly the dumbest new product from SEMA
Old Nov 1, 2016 | 01:08 PM
A "serpentine" belt conversion for Pontiac motors that uses an electric water pump.
Talk about lowering reliability while increasing cost.
Old Nov 1, 2016 | 02:56 PM
As a mechanical engineer, I believe I can confidently say that that thing offends the honor of my people.
Old Nov 1, 2016 | 03:06 PM
m371961's Avatar
Is that 3 idlers and mechanical tension? On both the AC comp and alt.?
"A fool and his money are soon parted."
Old Nov 1, 2016 | 03:10 PM
While the basic design premise is just stupid, you really have to love the cantilevered A/C compressor. Could they mount it any further outboard? What part of "fatigue failure" was not clear (plus, that's an ALUMINUM bracket, so fatigue happens much sooner than for steel).
Old Nov 1, 2016 | 03:24 PM
svnt442's Avatar
I'm looking at the belt wrapped a little less than half way around the crank pulley. Yeah....no thanks.
Old Nov 1, 2016 | 03:25 PM
CRUZN 66's Avatar
Olds Fever
Well they at least assaulted a Pontiac and not an Olds... Looks PRETTY for the show crowd...
Old Nov 1, 2016 | 03:38 PM
coppercutlass's Avatar
Chevy budget Olds powered
I had so any people tell me the moroso electric water pump drive was junk. I have been running one for almost 7 years on the street. I do carry a spare unit just in case as its very easy to swap the motor. But i guess thats actually more reliable/ versatile than a unit that would need to be rebuilt by the maker since its not easy to repair by most people.
But i agree its a horrible looking design.
Old Nov 2, 2016 | 07:17 AM
It's a horrible looking design with no functional benefit. At least it's expensive.
The limited belt contact on the crank pulley requires a LOT of tension in the belt to prevent slippage. The result will be MORE friction (and thus more HP loss) than with V-belts. This additional tension also means premature failure of the accessory front bearings. Yeah, this is a good design. There's a reason why true serpentine belt designs use a reverse-rotation water pump with the belt S-shaped (like a SERPENT, get it?) around the crank and pump pulleys.
Old Nov 2, 2016 | 10:24 AM
rustyroger's Avatar
'87 Delta 88 Royale
With a reverse flow belt drive to the water pump and a sensible A/C mounting it would make sense, and look good too imo.
Roger.
Old Nov 2, 2016 | 10:25 AM
Roger.
At which point, you wouldn't need a bazillion idler pulleys...
Old Nov 2, 2016 | 10:31 AM
I run the moroso drive in reverse. Just got flip the wires lol.
svnt442's Avatar
And isn't that angle on the power steering pump a bit extreme? You'd never get a proper reading on the dipstick at that angle and quite possibly not have the sump in the correct place to let the pump operate properly.
Old Nov 2, 2016 | 10:47 AM
rustyroger's Avatar
'87 Delta 88 Royale
I think we are missing the point, it's all about looks.
Two things that sell nowadays are cheap and appearance. Sound engineering, efficiency, and value for money are all discounted in these crazy times....
Roger.
Old Nov 2, 2016 | 10:53 AM
I like cheap and efficient. Wasn't that pretty much the sales pitch of volkswagen .
Old Nov 2, 2016 | 10:55 AM
Roger.
I have no problems separating idiots from their money...
Old Nov 2, 2016 | 11:10 AM
Bernhard's Avatar
Originally Posted by koda
as a mechanical engineer, i believe i can confidently say that that thing offends the honor of my people.
lol lol
I find it offensive on a visual, financial, impractical level.
Old Nov 2, 2016 | 02:26 PM
Run to Rund's Avatar
It'll sell. Remember that Pontiac stands for Poor Old Newby Thinks It's a Cadillac.
Old Nov 2, 2016 | 02:52 PM
No it doesn't.
Old Nov 3, 2016 | 06:12 AM
Do things like this end up at SEMA?
http://www.tornadoair.com/
If so, I think this Pontiac motor serpentine belt is far from the dumbest thing at SEMA?
Old Nov 3, 2016 | 06:14 AM
Point taken.
Old Nov 3, 2016 | 10:42 AM
OldSoldier's Avatar
Car Nerd
It looks to me from that photo that it needs to be a ways out to clear the valve cover. The compressor must interfere with it unlike the alternator which is probably shorter. Just a guess.
Old Nov 3, 2016 | 10:46 AM
The Sanden compressor is pretty short and looks like it fits in front of the valve cover in that photo. More to the point of structural design, the factory compressor mounts used beefy brackets that supported the compressor with a wide base to prevent vibration and fatigue failures. I realize the Sanden weighs about half of what an A6 does, but that's still quite an excessive cantilever with a very narrow base.
Old Nov 3, 2016 | 01:32 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Why so wide? It is just ridiculous.
Old Nov 4, 2016 | 09:51 AM
Mike77's Avatar
I think they call it form over function. Shiny a bright. someone with too much money and too much wine will buy it for their trailer queen.
Old Nov 4, 2016 | 12:05 PM
svnt442's Avatar
And the first time they start it the belt will slip and squeal all over the place....lol.
Old Nov 4, 2016 | 12:08 PM
rustyroger's Avatar
'87 Delta 88 Royale
"Live beneath your means" was one successful tag line.
Another was a Beetle driven over snowbound roads with the punchline; "How does the guy who drives the snowplow get to the snowplow?". Didn't ask how he avoided frostbitten feet though.
Roger.
Old Nov 6, 2016 | 12:25 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Break out the turd polish...and pig mats when filling the PS pump...
ScottoW31
Nov 12, 2013 06:43 PM
540 Olds
Non-Olds Engines
20
Oct 3, 2012 10:45 AM
leepear
Nov 13, 2011 06:33 AM
leepear
Oct 30, 2011 06:32 PM
MN71W30
Apr 29, 2009 12:10 PM
