POA vs "Cycling Switch"
Old May 4, 2016 | 10:45 AM
chip-powell's Avatar
Just a curiosity on my part. On a previous post we started discussing this, and then it just faded away. A month ago I bought a new cycling switch (along with many other a/c parts) to replace my bad POA valve on my a/c. I think that it works fine and does the job quite well for about $100 less than a reconditioned POA would cost. Since mine's a driver, not having a "true" POA under the hood does not bother me.
Other than supposedly being more efficient, does anyone know the differences between a POA and a cycling switch? Here are some links...
http://www.classicautoair.com/POA-GM-Valves-Home.html
https://www.opgi.com/cutlass/1971/co...oning/CH28459/
Old May 4, 2016 | 10:57 AM
banny's Avatar
guys don't like the constant cycling. And because of this there are complaints of it not seeming to get as cold as with a poa valve. If using with an original steel a6, could wear out the clutch as a6 compressors were designed run continuously.
Old May 4, 2016 | 11:08 AM
Banny said it.
A cycling valve cycles the compressor.
A POA valve regulates the refrigerant flow.
Old May 4, 2016 | 02:34 PM
Aaaahhhh. Thanks.
rcdynamic88
Aug 24, 2014 09:41 AM
Silchad
Sep 12, 2012 09:38 AM
ThePackRat
Jun 11, 2012 05:28 PM
Al Graaf
Apr 6, 2012 08:46 PM
