Please help with some crank advice
Old April 20th, 2021 | 06:35 AM
Bgdaddy455's Avatar
Good morning,
I have a 71 455 block i just picked up(standard bore but some rust in the cylinders) My old block and crank are toast about and im about to send the new block to the machine shop and need some advice on the crank.i had a Nodular crank in my old block that ended up getting destroyed and i was just cruising on the highway at about 2800 rpms. My question is are the eagle cast steel cranks better (stronger) than the Nodular? I know it would need to be checked and machined if out of spec. I am having a hard time finding a Nodular here in southeast michigan so eagle may be my only choice. I also have a buddy who just moved here from florida and he has a 69 toro motor (mild cam)with less than a hundred miles on it that i can have. The problem is that it has been sitting in a crate at a boat yard in Ft Lauderdale for 10 years so i have no idea what condition its in. I do have some family there so i might just go for a visit and grab it.
Old April 20th, 2021 | 07:30 AM
Just about every factory 455 crank is nodular (except for the rare 1968 forged cranks).
Old April 20th, 2021 | 10:15 AM
Bgdaddy455's Avatar
Joe do you know if the eagle crank is as good or better than the Nodular? The block i bought came with a crank but when i looked up the numbers it seems to be the least desired cast crank
Old April 20th, 2021 | 11:04 AM
70W-32's Avatar
The Eagle crank is cast, just like the original Olds cranks. Its only advantage(if it fits correctly) is that its not 50 years old
I have 2 N cranks. Im about 30 miles north of you. Both would need machining, theyve been sitting for 30+ years. If youre interested, PM me. $100 each
Old April 20th, 2021 | 11:18 AM
Bgdaddy455's Avatar
thanks for responding and i am interested in the N crank. How bad are they? Scoring, worn excessively? etc
Old April 20th, 2021 | 11:46 AM
70W-32's Avatar
Both are currently std/std. No spun bearings, but crusty from sitting. I would think either would clean up at .010 under
Old April 20th, 2021 | 11:54 AM
Bgdaddy455's Avatar
sounds good. Not sure how PM works on here but i could come by thursday if that works for you. Just need a time and an address?
Old April 20th, 2021 | 12:20 PM
70W-32's Avatar
Sorry, gotta retract my offer. Just took a look at them and they look very crusty/rusty. Apparently theyve been sitting under all the winter boots getting wet. Not sure what it would take to clean up. Sorry.
Old April 20th, 2021 | 12:28 PM
Bgdaddy455's Avatar
thanks anyway. Do you know anyone else that may have one?
Old April 20th, 2021 | 12:50 PM
70W-32's Avatar
Id check with either of these places
performance crank 586-549-7557
Crankshaft Craftsman 248-313-9685
Old April 21st, 2021 | 07:12 PM
64Rocket's Avatar
Those cranks look good! The fles\x plate looks a little ruff. A good sand blasting and i bet they would be good.
A good crank shop should be able the clean a polish. A 10/10 machining would be a good choice.
Gene
Magna86
January 15th, 2021 08:46 PM
EJC
February 20th, 2018 12:23 PM
cutlassefi
May 3rd, 2017 06:03 AM
wr1970
December 8th, 2015 08:14 PM
Stborden
October 22nd, 2008 09:51 PM
Quick Reply: Please help with some crank advice
