455 Olds Crank question
Old Feb 19, 2018 | 01:17 PM
EJC's Avatar
EJC
Hello Everyone,
Just got a call back from the machine shop on my crank, it is a Nodular crank for my 455 build and I am being told it needs to be turned to 20/20. Anyone know of or had an issue with a gring at .020 or should I look for a different crank?
Old Feb 19, 2018 | 01:43 PM
cherokeepeople's Avatar
if you were closer i think i have 3 or 4 steel cranks.
Old Feb 19, 2018 | 01:58 PM
cutlassefi's Avatar
You’re fine at .020/.020 and with a Nodular crank if you keep your hp level below 600.
Old Feb 19, 2018 | 02:10 PM
EJC's Avatar
EJC
Cool, thanks for the input. The machinest had to bore the block to .060 over so I guess thats the last bore on this block. Would you suggest any 1 bearing brand over the other Cutlassefi?
Old Feb 19, 2018 | 05:40 PM
cutlassefi's Avatar
Federal Mogul main bearings 108M in a .020 under. Rods I just use the Clevite P bearings. And the Durabond 06-B is the best cam bearing to use imo.
Old Feb 20, 2018 | 12:23 PM
EJC's Avatar
EJC
Thanks for the info on that.
Bernhard
Nov 24, 2022 09:12 AM
bob p
Apr 10, 2015 01:55 PM
Bernhard
Jan 6, 2013 09:27 PM
Al2011
Feb 23, 2012 06:52 AM
sx455raidercelticfan
Nov 23, 2010 05:45 AM
